side by side error when trying to open VSx3
tmcevoy
motherboard: Acer Aspire
processor: 2.13 Intel I3
ram: 4GB
Video Card: Intel
sound_card: Intel
Hard_Drive_Capacity: 320GB
Post by tmcevoy »
I install recently downloaded VSx3. After installation, I get a side by side error message telling me to look at event log or use sxstrace.exe. I have repeatedly uninstalled and reinstalled. No luck. Here is what the event log shows. I am using an Acer laptop with Home Premium Windows 7. VS is the only program on my computer that is having this opening problem.
Activation context generation failed for "C:\Program Files (x86)\Corel\Corel VideoStudio Pro X3\vstudio.exe". Dependent Assembly Microsoft.VC80.ATL,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50608.0" could not be found. Please use sxstrace.exe for detailed diagnosis.
Very frustrated, thanks for any help.
TM
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Re: side by side error when trying to open VSx3
Post by Clevo »
What does Event Viewer say?
Either way it looks like you have a corrupted download and you will need to download again.
Rob717
motherboard: Intel DP45SG Intel P45 Express Chipset
processor: Intel Core 2 Quad Q 9550
ram: 8 GB
Video Card: ATI Radeon 4870 1GB
sound_card: On-board
Hard_Drive_Capacity: 2 TB
Post by Rob717 »
tmcevoy wrote:I install recently downloaded VSx3. After installation, I get a side by side error message telling me to look at event log or use sxstrace.exe. I have repeatedly uninstalled and reinstalled. No luck. Here is what the event log shows. I am using an Acer laptop with Home Premium Windows 7. VS is the only program on my computer that is having this opening problem.
TM
This is an issue with the Windows OS, you need to remove C++ Redist and then re-install them. It could be corrupted or damaged, you might need to use a tool to remove them from your system.
You should have 2005 and 2008 C++ Redist located under the Add or remove or Programs and features depending on what version of Windows you are using. Remove all of them and then re-install. You can get the installers from Microsoft.com
tmcevoy
ram: 4GB
Video Card: Intel
sound_card: Intel
Post by tmcevoy »
Tried that for several days, but thank goodness right after posting this question I finally fixed it. There is a Microsoft 'security fix' for those redistributable files. After installing them, the program opens with no problem. I think it is sad that I had to go on a Google dumpster dive search for days to find some link of information on that. But the issue was Microsoft, not Corel. Thanks all!
Clevo
ram: 4GB
Post by Clevo »
...and thank you for posting the fix...it may help others.
