codec question
sleeper
- motherboard: Asustek M4A78T-E
- processor: 3.4 GB AMD Phenom 2 X4 965
- ram: 8 mb
- Video Card: ATI Radeon 5800
- sound_card: ATI High def audio device
- Hard_Drive_Capacity: 1 tb
codec question
I have a sony 550v camcorder. It records in h.264. I am having problems after creating share file and trying to burn in 7se. The video plays for 2-3 seconds then stops and goes back to the start and does it again. I have tried different share formats, reinstalled vs3 and 7se. It doesn't help. I did make 2 movies that played fine but none since. I even used 5 clips to make a video and it also burned to a hybird disk without any problems. I was wondering if I should change the video codec to mpeg2 edit then change back to avchd when I make a share file? Any one think this will help? Any other ideas would be appreciated too. Also my bluray burner is stuck on max. burn speed. I can't change it.
Re: codec question
I think we need to sort out what those numbers are first sleeper - by VS3 do you mean you are using version 3 of VideoStudio ?? and what about 7SE - is that VideoStudio 7SE or some reference to Windows 7.
In order to help we need as much accurate information as you can supply about what you are using.
sleeper
- ram: 8 mb
Re: codec question
sorry. vs prox3 and moviefactory 7se. my video is 24 min long at rate of 16000. could this be too big? When I took the 5 video clips, it was only about 4-5 min. long from the save video and it worked fine. If you need any other info please let me know. I have been working on this video for a month now.
