VideoStudio Pro X3 and Smart Render
alexs29
operating_system: Vista Ultimate
motherboard: Asus A8n
processor: Athlon 64 X2 3800+
ram: 2GB
Video Card: ATI Radeon 4850 512MB
sound_card: Creative Audigy SE
Hard_Drive_Capacity: 1.5TB
Post by alexs29 »
Greetings to All!
First of all I want to tell that this program is interesting to me because it supports editing of files AVCHD without recoding. But I have a problem at its usage.
I create the project, add 1 file M2TS created by my camcorder (Panasonic HDC-SD60) in it and trying to make export to a file as file AVCHD (HD PAL 1920). Smart Render is on.
When advancement of 90% Video Studio hangs. Ок, we wait...
Approximately after 5 minutes it unhangs, the performance indicator disappears, but the studio remains freezed. ОК, we wait still...
Then it unhangs and there is a message appears: "File Format mismatch 16803:1:3". The file created by a studio in 3-4 times longer, then source file, with the damaged header, without a sound.
I have tried to reinstall VS - the same, have deleted a codec pack - the same, cleaned the register, have deleted temporal files - the same. And each time is frozen on 90 %.
I tried to do it with different files. Nothing has helped.
What can it be?
Re: VideoStudio Pro X3 and Smart Render
Is your PC a dual-core or Quad-Core? The latter is highly recommended for AVCHD. Have you tried rendering without Smart Render?
alexs29
ram: 2GB
Post by alexs29 »
My PC is dual-core. Without Smart Render everything OK. But I don't want to recompile files as I already wrote.
Post by Black Lab »
It has been mentioned many times on this board that when outputting HD, especially AVCHD, SmartRender should be turned OFF.
Post by Trevor Andrew »
If you are converting your Panasonic m2ts files using H264 to Avchd HD Pal 1920 then the settings have to match for Smart Render to take affect, if the bitrate is different then every frame will need recoding irrespective of what edits you have applied.
AVCHD are not the first files to be recommended that Smart Render be disabled.
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
There is something in the Panasonoc AVCHD codec which causes this problem with VX2/3. If you want to keep smart render (much faster too) with the Pana files, just put in front your video an image file (I use black .jpg set for 4 secs).
alexs29
ram: 2GB
Post by alexs29 »
Ок, I will try to add a picture in the beginning. Though it is strange, with other programs there are no such problems at all.
For example, with Sony Vegas Movie Studio everything ok. It also supports Smart Render. I have recently bought a camcorder and searching normal not to expensive program for work with video.
