With compliance to the rules, I have appropriately filled out the required (system specifications) information asked of each user.
Describe your problem: I have not encountered a single problem when working with the program. The problem appears after using it. An error pops up, with the below screen-shot.
Image removed.
It will be followed by a confirmation that the application crashed.
Image removed.
Problem Details:
Properties of your source files, including video, audio, image files (format, file size, where did you get it?): N/AProblem signature:
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Version: 13.0.0.0
Application Timestamp: 4c255e23
Fault Module Name: veui32rc.dll
Fault Module Version: 8.0.0.0
Fault Module Timestamp: 4c255f73
Exception Code: c000001d
Exception Offset: 0000bb69
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1033
Additional Information 1: 8ab8
Additional Information 2: c74ca49d49272b0fb25549ee16b7664d
Additional Information 3: bb15
Additional Information 4: 5dfbfe58509de719c4f0b64c44d4995a
What devices are involved and their mode of connection?: N/A
Project Properties (important): N/A
Output format (file, DVD, VCD, SVCD): N/A
Output Properties (cogwheel in lower left of burn screen): N/A
PAL or NTSC: N/A
Error Codes (if any): N/A
Product Version: Corel VideoStudio Pro X3
As stated above, I have not experienced a problem when working with my videos therefore the above information need not be disclosed. However, if I am obligated to, I shall submit.
Attached are the dump files.
Thank you.
Erudite
