I'm trying to make DVD with DVD MF 6, but no success. Was googling, lots of google results directed into this forum, so I decided to register here
Then afterwards lower and upper field first DVD authorings both are giving bad results, like vide is shaking sometimes. Progressive capturing, and then frame-based DVD creating is not helping also. I decided to try something better, for example capture with DVD MF 6, but strange - looks like video is capturing ok, I can hear sound, but in the actual video file there are only 2 frames, I have no idea why it could be. So the problem is how to capture video with upper field first, seems programs don't want to work for me. Any help would be appreciated.
I tried lots of different settings, mostly 6000kbps, mpeg-2 video, mpeg-1 audio, different interlace modes. In this forum I found Search found 291 matches: winfast
"The Interlace mode only has one encode mode now.
So it will only have lower field first.
If you want to make good quality of picture, please use Progressive.
Sorry for your inconvenience."
Is it really true? This is a bit strange, because in Winfast PVR2 I can select 5 interlace modes. Capturing in progressive mode, and then with MF doing non interlaced giving bad results. Also lower field capturing to lower field dvd making - similar shakes each few seconds
