WinDVR 3 was installed by a long since replaced TV Capture Card. I recently started getting a "Key Expired" Popup whenever I try to navigate in Windows Explorer or when I try to click Video Files.
I traced the problem to WINDVR3 by finding and reviewing the following files
C:\DOCUME~1\Name Removed\LOCALS~1\Temp\WER1b13.dir00\WinDvr.exe.mdmp
C:\DOCUME~1\Name Removed\LOCALS~1\Temp\WER1b13.dir00\appcompat.txt
I have searched my C:\ for WinDvr.exe but it does not find it. I have followed the instructions to remove WinDVR3 at http://phpbb.ulead.com.tw/EN/viewtopic.php?t=21757
I have carefully followed and repeated the instructions numerous times, however I continue to get the "Key Expired" popup when trying to navigate Windows Explorer or play or access video files. It's been very frustrating. I am looking forward to some advice on how to finally and completely remove WINDVR3 from my system.
Thank You
Jack
Unable to Remove WINDVR 3
Moderator: lata
nepenthe
- motherboard: Gigabyte GA-P55A-UD3P
- processor: i-7 860
- ram: 16 GB
- Video Card: Gigabyte GeForce GTX 470 SOC
- sound_card: onboard Realtec audio
- Hard_Drive_Capacity: 600 GB
- Monitor/Display Make & Model: NEC MultiSync EA192M
Re: Unable to Remove WINDVR 3
Watsonaka -
You might consider the free download CCleaner:
http://www.piriform.com/ccleaner
Run the Registry Cleaner.
nepenthe
nepenthe
watsonaka
- motherboard: ASUS M3A78-CM Socket AM2+ uATX Motherboard
- processor: AMD
- ram: 4GB
- Video Card: ATI Radeon 3100
- sound_card: Via High Def
- Hard_Drive_Capacity: 1TB
I failed to mention that I ran CCleaner early on in my quest to rid the "Key Expired" popup. Any further advice would be greatly appreciated. The popup is frequent and borderline maddening.
Thanks Jack
Thanks Jack
watsonaka
- processor: AMD
- ram: 4GB
Ok I ran HiJackThis and found the following:
O4 - HKLM\..\Run: [WinDVR SchSvr] "C:\Program Files\Common Files\InterVideo\SchSvr\SchSvr.exe"
This item was not showing in my task manager. Seemed to be running stealth. I manually deleted it and all other WinDVR entries from the registry. rebooted and so far so good. Thanks for the forum & the input. I'll holler if it comes back.
Thanks Jack
Thanks Jack
nepenthe
- ram: 16 GB
Watsonaka -
Glad to hear the glitch is resolved. My next suggestion would have been reinstallation and subsequent removal with Revo Uninstaller:
http://www.revouninstaller.com/
Uninstall using 'advanced mode' and delete all the registry entries.
nepenthe
nepenthe
