Subject says it all. The reason I'm asking is that I'm toying with getting a new PC with a Core iX (3|5|7) CPU. I'm finding that at a given price point, there are two options: 1)fewer/cores/threads with higher clock speed; 2)more cores/threads with lower clock speed
So, if VXS3 is multi-threaded, that argues for option 2: rendering on four threads is going to get the job done a lot faster than one, even if each thread is relatively slow. If VXS3 is single-threaded, that argues for option 2: doesn't matter how many cores/threads you have, if only one will be used for rendering, so just get the fastest CPU you can afford, regardless of core/thread count.
I understand there are other complications (memory management, bus speed, etc.), but unless I'm mistaken, if VSX3 is single-threaded, it just boils down to clock speed.
Any advice/insights?
TIA,
UncleBoo
Is VSX3 multi-threaded?
Re: Is VSX3 multi-threaded?
Corel says:
I think core utilization depends on what you're doing. Some of the CODECS may not be multithreaded.Super-charge your workflow with GPU acceleration and multi-core Intel® CPU support for faster editing and rendering.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
I'm not sure about general usage but I know rendering is.
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Guy Lapierre
