Windows 7 Tweaks for Video Editing?
blplhp
motherboard: Dell Motherboard
processor: AMD Phenom II 6-Core 1055T
ram: 6GB
Video Card: ATI Radeon HD5670
sound_card: Soundblaster
Hard_Drive_Capacity: 1TB
Post by blplhp »
Has anyone compiled a set of Windows 7 tweaks for video editing optimization? Or is Windows 7 optimization the same as every other Windows platform before it? I know Corel/ULEAD still recommend 1) enabling DMA of the IDE drives (make sure you download the latest Microsoft ADMA patch first) 2) disabling write caching on the hard drive and 3) setting the minimum and maximun values of the Page File to twice the amount of RAM you have on your computer. I've always heard the Min. value should be 2x of RAM and the Max. value should be 3x of RAM. I've also read that Indexing should be disabled.
Are all these tweaks still necesary in Windows 7 Home premium (64 bit) on a computer that has a 6-core 2.8GHz processor, a 1TB SATA II Hard Drive (7200 RPM and 3.0 Gb/sec.) and 6 GB of DDR3 SDRAM at 1333 MHz? My Page File's minimum and maximum values need to be 12GB each?
If disabling write caching is still recommended, is it recommended to disable it only when one is capturing video, and then restore it back to "Enabled" when done capturing? Or do you leave it "Disabled" all the time? What's the purpose behind disabling "write caching"? Everything I've read on-line about this says "enabling" write cachng increases hard drive performance and the only reason to disable it, is if you are going to be removing the device frequently. Does "Disabling" write caching have any negative effects of any other computer applications ( other software, internet usage, spreadsheets, internet downloading, etc.)?
Any others tweaks for Windows 7?
Thanks,
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Sony DCR-TRV315 Camcorder
Canon G10
Canon 40D
GuyL
motherboard: ASUS P6T
processor: I7 920
ram: 6GB
Video Card: ATI 5870
sound_card: Auzentech X-fi Forte 7.1
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: LG W2753V & HP w2408h
Re: Windows 7 Tweaks for Video Editing?
Post by GuyL »
I've not tweaked windows for video editing for a long time. I believe I stopped doing so right around the time I stopped capturing analog video through a capture card. Outside of making sure windows update, virus scans, etc don't start in the middle of your work, I honestly don't think much is needed if you have half decent hardware. I do regular web surfing, email, etc while rendering video and burning projects without issue. Looking at your hardware profile I don't imagine you will have any issues either.
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
blplhp
ram: 6GB
Post by blplhp »
Thanks GuyL. I appreciate your comments.
Any one else have any comments? :D
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
