burning problem
Several users have been unsure where to post issues relating to the copy of MovieFactory 7 SE now supplied with VideoStudio X3. To make life easier you can post problems here.
sleeper
motherboard: Asustek M4A78T-E
processor: 3.4 GB AMD Phenom 2 X4 965
ram: 8 mb
Video Card: ATI Radeon 5800
sound_card: ATI High def audio device
Hard_Drive_Capacity: 1 tb
burning problem
Post by sleeper »
In 7se, I go to inport media. I use the disk or hard drive button. I have 3 choices 1is c:\users\jan\document\corelvspro\my projects.
The second is ..........\corel video studio pro. The third is c:\users\jan\videos\russia. Now nomatter which choice I choose, the next screen says "c;\uses\jan\document\corelvspro\corelvspro have no valid content." I click on the "okay" button and it then loads all the share files I have in vs and the russia video clips. I only check the share file I want to import.Before I do this I check the clog wheel at the botton left and make sure the settings are like my first video clip. Is all this correct ? I am getting a loop in my burn video. It plays for 5 seconds then goes back to the beginning and starts again.
sleeper
ram: 8 mb
Re: burning problem
Post by sleeper »
I hope the moderator's don't mind my posting this here also. I just want to share my success and hopefully help others. I found imgburn to use after editing with vs.It burned my avchd disk without any problems. It does have a learning curve with it but it is free and works. As Ken said lower the burning speed and I can with this program. So if you can make a share file with vs but it won't work in your blu ray player, try another burning program, lower the speed of the burn and see it that will do it. Thanks again Ken for your help and Ron.
