recognizing panasonic camera
krieger
motherboard: belarc advisor
processor: belarc advisor
ram: 4 gb
Video Card: belarc advisor
sound_card: belarc advisor
Hard_Drive_Capacity: belarc adv
Post by krieger »
I just purchased the corel video editing software. It does not recognize my Panasonic HDC-TM700P video camera. The reason I purchased Corel is because I read that it can recognize ACVHD files. I know that the camera is being seen by the computer because the Panasonic software initiates and sees the camera. How can I get the Corel software to capture the camera data? Thanks.
Re: recognizing panasonic camera
Post by Black Lab »
What does the Panasonic software do? If it is for capturing or transferring video you should use that, then import the clips into VS for editing.
Doesn't that camcorder record onto a memory card? If so you can just copy the video files from the memory card onto your computer. Then insert them into VS for editing. Do you have a card reader for your PC?
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
I'd go with jeff's advice and use the panasonic software to transfer the data to your pc then import and edit in VS. You don't "capture" from this type of cam.
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
I have TM700 and use it with VS. Just connect the camcorder through USB with yout computer. Your PC will see your cancorder as an external device, Just copy the .mts files from the "Stream" folder (in the "Private" folder) on your HDD. Open this files in VS and you are done.
