Can't find the Ulead Particle Plugin
A forum dedicated to Vista / Windows 7 related fixes and work rounds in relation to Corel's Intervideo/Ulead range of products.
Temari
System_Drive: D
motherboard: Quanta 30B7 65.2C
processor: 1.60 GHZ AMD Turion 64 X 2
Video Card: NVIDIA GE Force GO 6150
sound_card: Conexant High Definition Audio
Hard_Drive_Capacity: 100.03GB
Post by Temari »
Hello,
I just downloaded the Ulead Particle Plugin to use in my Photoshop Elements 7 and I can't find it. When I tried using it, I got a msg that said unable to load particle.dll I know it installed correctly because I saw the info, icons, uninstall icons, etc. So, I wonder if I did anything wrong?
Could someone please help me find a way to find the Ulead Particle Plugin? Thank you!
Your help is appreciated.
Temari
:arrow: ** Admins, if I posted this in the wrong topic, please feel free to move it to the right one. Thanks! **
MySnip,4ULEAD,unable 2 load,7-29-10.JPG (28.66 KiB) Viewed 15671 times
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Can't find the Ulead Particle Plugin
Post by LeviFiction »
This plugin was obviously developed for older systems and not improved to work specifically with Vista or Windows 7 so it's possible this is the problem. The particle plugin(particle.8bf) actually uses another plugin (particle.dll)to provide most of its functionality. So when the plugin attempts to load this other plugin it gets that error. However, when running as admin I get no such errors and it runs just fine. So if you want to use this plugin you will have to run Photoshop as administrator.
marta
ram: 4GB
Hard_Drive_Capacity: 1Terabye
Post by marta »
I got it to work in photoshop CS (WINXP) by copying every single .dll from the ulead particle folder into my Windows>system 32 folder
