PSPPX3 Color Balance Window
ronzie
motherboard: ASUS P4-800E Deluxe
processor: Intel P4 3.3 GHz
Video Card: PNY GT6800 AGPx8
sound_card: Hercules Digifire 7.1
Hard_Drive_Capacity: 360 GB
Monitor/Display Make & Model: NEC Multisync P221W with Spectraview Calibrator
Post by ronzie »
Disabling the use full screen preview so I get the before/after samples, anywhere I pick within the origin area near a white or gray zoomed area, I the eye dropper invalid selection. How close do the RGB values have to be to enable the smart balance feature? I have all of the sliders set at neutral 0.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: PSPPX3 Color Balance Window
Post by LeviFiction »
Does the eye-dropper have the invalid selection symbol (circle with a line through it) or do Temp and Tint say invalid? Because you should be able to select the option even though Temp and Tint say invalid.
ronzie
Post by ronzie »
Temp and Tint box show invalid warnings. It does let me place the balance point and it does have an effect. It gets close but no cigar as the saying goes. I tried an extreme sample change and it worked anyway.
Thanks.
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Re: PSPPX3 Colour Balance Window
Post by Trev Bowden »
Smart balance is the default and you will see its selected a Gray in the left preview. If you use the dropper to select a white Gray or black you are over riding the smart select IE setting what you wish to be white. Then you can adjust temp tint Using the lower set of sliders to make that selected white , white, pink or purple. I would recommend White :shock:
