Materials Palette/flood fill back ground
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I am trying to select, for instance "Crumpled paper" from the materials pal in PSPro X so that I can flood fill an erased background with it.This crumpled paper
appears in the box on the right in the dialog box but I cant find a way to to make it current.Can only do this with items from the box on the left.Can some one
advise me , in detail ,how to do this please.....................Ken
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Re: Materials Palette/flood fill back ground
Post by Trev Bowden »
That box on the right Is fro adding a texture to a colour thats a semi transparent effect that probably don't want You have to check the texture box at the top to make it active. What you want Is a Patern fill of crumpled paper. I bet a little light just appeared over your head. chose the fill tool in the materials pallet chose pattern and click the right edge of the pattern. There is a little arrow head but you may find it hard to see. Now you can select crumpled paper if you have it. I don't I only have a texture for crumple paper so what to do.
Flood fill your image with whit or whatever paper colour you want Don't have the texture checked just plain coloured paper. Now go to Effects > Texture Effects > Textures their you can chose the crumpled paper texture and adjust how high you want and also the scale to get just the effect you want
Ken Veal
ram: 32 GB
Post by Ken Veal »
Fanks Trev,
I give that a go
Ken Veal
ram: 32 GB
Post by Ken Veal »
Followed the above advice but it did not work—I am not doing something right here.This was my workflow
1 select flood fill tool
2 clicked the top foreground +stroke prop box in mat. pal
3 “ “ drop down arrow next to the box on the right of mat.prop box
4 selected crumpled paper OK
5 unchecked texture OK
6 went to effects—text effects---texture
7 in texture box via drop down arrow selected crumpled paper OK
8 clicked on erased background of image with flood fill tool and the previous selected marble
pattern filled the image instead of crumpled paper.
So where am I going wrong
Trev Bowden
ram: 4gb
You will want a background colour first. I suggest white. With that layer active do Effects Texture Effect Texture Select the crumpled paper click OK and your white background now has a white crumpled paper effect.
That was method one. You mixed Two ways together. The other is to set white as the flood fill colour and check texture with crumpled paper as the texture then flood fill the background layer.
The strength of the effect will depend on the colour used Darker colours are not as pronounced and The Texture effects texture will give more control then the simple Fill.
Just remember its a texture effect your adding Not a Crumple paper pattern But you could save a small plain image with the effect on it as a pattern should you which But Use the effects , image effects. Seamless tilling first before you save it to get a pattern that does not show the repeats or joints.
