I have followed this link very carefully to uninstall any trace of Apple software on my PC and reinstall Quicktime ONLY, and I still have the same problem. Please someone help me!!!
_______________________________________________________________________________________________________________
Hi everyone, hopefully you can assist me!
My computer specifications are in my profile.
I use VST X2 to edit for a homegrown sport known as Koneball. I have recently changed onto a laptop for editing from a friend's house, as he has moved across the country, so I can't use it any more. Before I used VST X2 on my friend's computer and everything worked fine. I have uploaded some of this material to YouTube, so you can get an idea of what VST X2 has to render:
The video file is recorded from my Panasonic Lumix as a .mov, 848x480, 30/fps, Data rate 11232kbps. The audio from this is at 256kbps bit rate, mono, and sampled at 16kHz. The audio is mp3, and the graphics you see on screen are .png, apart from the scoring which is an internal title. Everything is stored in folders on my hard drive, C:
I render the project the same as the project settings, which comes out as a PAL MPG, 720x576, 25/fps, Data rate 8000kbps. The audio is 1536kbps and is stereo, sampled at 48 kHz. The matches are usually 4-6 minutes long with mostly crossfade and the occasional mask as a goal transition.
Now though, I have issues when previewing the project at times, but I get round this by not previewing and dragging what I call the timepoint over to get a preview myself. When I have completed the project, I click Share... , Same as Project Settings, and it begins to render. Everytime I try to get a project rendered, it mostly crashes at different points in the project. This is what I get up most of the time:
At the first crash..
Code: Select all
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Version: 12.0.0.0
Application Timestamp: 48c12aa3
Fault Module Name: CoreAudioToolbox.dll
Fault Module Version: 7.9.3.0
Fault Module Timestamp: 4bff36a9
Exception Code: c0000005
Exception Offset: 00273bd9
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789Code: Select all
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7600.16385
Fault Module Timestamp: 4a5bdb3b
Exception Code: c015000f
Exception Offset: 000845bb
Locale ID: 2057
Additional Information 1: 0871
Additional Information 2: 0871f856c07a4f47d01f4422b5f61a3b
Additional Information 3: 90d8
Additional Information 4: 90d86e2c05b1ddc1880e2836c44cff52I have a lot of editing to do and I want to get this done ASAP, any help would be greatly appreciated.
Cheers,
Chris
