Background eraser PSPro X
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I keep the brush centre near to the object contour which usually works fine, but frequently I am left with a coloured thin line (not a halo) around for instance a persons arm in parts of it.What am I doing or not doing coerrectly..................Ken
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Re: Background eraser PSPro X
Post by Trev Bowden »
There could be many causes the most likely is its a small image therefore Jpeg artifacts and Anialysing are the causes. In such cases make a selection around the item, Rectangular, Click the layer opaque to shrink it to just the item then contract a couple of pixels, Invert, delete.
Ken Veal
ram: 32 GB
Post by Ken Veal »
Thanks for the info Trev.Would it be possible to have a click by click workflow please,your dealing with a PSPro novice here.
Trev Bowden
ram: 4gb
Well after you have removed the background You should have transparency around it . Drag out a rectangular selection around it . Now left click in the centre of the selection. the marching ants will jump to just surrounding the image. Now do Selections, Modify, contract you should only need 1 or 2 pixels. Now you need to invert the selection so that its the space around the point of interest and delete it. Also you might find that you could avoid the white/ matting by adjusting the sharpness setting on the BG eraser. But you sometimes get this matting even when using selections So its a worthwhile trick to know
