SV Pro X2 playback too fast
wade61
- motherboard: 0D501F 200 megahertz
- processor: 2.50 gigahertz Intel Core2 Duo
- ram: 4GB
- Video Card: NVIDIA GeForce 8600M GT
- sound_card: Dellsound
- Hard_Drive_Capacity: 500 GB
I'm capturing from a Panasonic GS-15 Mini DV camcorder. After I capture and go to edit my video is under half the original size and playbacks in fast motion.
Re: SV Pro X2 playback too fast
Welcome to the forums,
How are you capturing, firewire? What settings are you using to capture, DV, AVI (RAW), MPEG-2 (DVD), or some other format? Please read the sticky at the top of this forum titled.. Please Read This First.... and return with more information so that we can better help you..
wade61
- ram: 4GB
Sorry about that. I'm using USB and I have tried DV, AVI (RAW), MPEG-2 (DVD) with the same results.
With a DV cam you MUST use a firewire cable connected to a firewire card. If you do not have one in your pc they are very affordable and super easy to install.
Jeff
Dentler's Dog Training, LLC
Look at the help, Press F1
Getting Started—Setting up your computer—Connecting a video camera to the computer. Shows how to connect via firewire (IEEE-1394)
Mini DV type camcorder.
The camera footage is recorded to tape as DV-Avi.
When you capture via firewire the video is transferred to the computer, there is no re-coding, what you have on the camera is what you get DV- Avi
Its a little like Downloading / Transferring except it is done in real time, whilst the tape plays.
View your pc’s device manager to see if you have IEEE 1394 Bus host controller. If yes, then all you need is a cable, usually 6 pin to 4 pin.
