Help fails - displays Web Works error
Mr Rocket
motherboard: GIGABYTE GA-EX58-UD5
processor: Intel Core i7 920
ram: 6GB
Video Card: ATI Radeon HD5870
sound_card: Creative xFi
Hard_Drive_Capacity: 2GB
Post by Mr Rocket »
I cannot seem to get the Help menu item to work at all. Every time I select Help -> Help Topics... I get a dialog box with the following error message: Web Works Help display fail! Any ideas? I've reinstalled PSP twice. And I downloaded the latest update.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Re: Help fails - displays Web Works error
Post by df »
There is now a PDF version of the manual that you can download.
http://forum.corel.com/EN/viewtopic.php ... &hilit=pdf
Regards, Dan
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Well that's for PSPX3, which is great if that's what Mr. Rocket is using because that error sounds like he's using an older version that relies on the old help system not the web based one. But I could be wrong.
Just to be sure, which version of PSP are you using Mr. Rocket?
Mr Rocket
ram: 6GB
Post by Mr Rocket »
I'm using the latest version, 13.2.0.35. But I've had PSP since the good 'ol shareware days! Could it be I have some leftover software that is getting in the way of this version?
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Post by Trev Bowden »
The X3 Help is online something , most likly your firewall, is blocking it from opening to the web page.
Quixote
motherboard: Dell M1210
processor: 2.15 gigahertz Intel Core 2 Duo
ram: 2GB
Video Card: NVIDIA GeForce Go 7400
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 120GB
Post by Quixote »
I just installed Corel PSP X3 today and have the same problem. I added PSP to the firewall exception list but it made no difference. Same error: "Web Works Help display fail!", when I click Help/Help Topics... on the menu.
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
What web browser are you using?
Is Javascript enabled?
Tim Morrison
C-Tech Volunteer
Quixote
ram: 2GB
Post by Quixote »
I'm using IE8 and Javascript is enabled and up to date. If I click "Help/Online Support and Resources..." it opens the Corel support page in IE8 so that link is working.
marty2010
motherboard: Gigabyte Z68A-D3H-B3
processor: Intel Core i7 2600k
Video Card: NVIDIA GeForce GTX 550 Ti 1GB 8.17.12.8026
sound_card: Realtek
Monitor/Display Make & Model: Viewsonic , VX2250WM-LED, 2 each
Post by marty2010 »
For problems in general I always try a Windows Update just to make sure a needed file is not missing.
Edit:
I have checked today and all is ok using Corel PSPX3 "Help" with both IE 8.0 and FireFox 3.6.3
Best Regards,
Vaughan Martell
Quixote
ram: 2GB
Post by Quixote »
I made sure all Win updates had been applied. There were two updates to MS Visual C++, not required before installing PSP, which were installed. I rebooted after the installation to make sure they "took". But, I still get the same error message when trying to access any help on Corel PSP X3.
grumpfuttock1
motherboard: MEDIONPC MS-7646 1.0
processor: 2.80 gigahertz AMD Phenom II X4 925
ram: 4 GB
Video Card: ATI Radeon HD 5670
Hard_Drive_Capacity: 3499 GB
Post by grumpfuttock1 »
Hi from a newbie to this forum.
I have been frustrated with the same "Web Works display fail" error after recently purchasing X3. I have frequently checked back here to see if there was any workable solution. I also contacted Corel Support.
I have just received this reply, which may be of help to anyone with the same problem, or maybe my simpler solution mentioned at the end of this post may work...
(From Corel Support)
"You might need to clear your browser cache in Internet Explorer and change its settings to default state. Please follow these steps:
1. Open Internet Explorer 8 (make it a temporary default browser if you're not using this for web browsing).
2. Click Tools, Internet Options.
3. Click the "Delete Files..." button under Browsing history in General tab.
4. In the new window, select Delete all.
5. Under Advanced tab, select 'Restore Advanced Settings' then click Reset button.
Try running again your Corel PaintShop Photo Pro X3, then and see if you can access the program Help."
Not wanting to loose some of the browser data in IE, I first tried to change my default browser from IE8 to Firefox, to see if that made any difference. YIPPEEEEE ! It worked on the first try :D
John.
Quixote
ram: 2GB
Post by Quixote »
Taking a clue from grumpfruttock1, I switched my default browser to FireFox, opened PSP X3 and opened the help and it worked, bringing up help in FireFox. Then I switched the default back to IE 8, closed PSP X3 and reopened it and that worked, too. Now it seems to work in IE 8 consistently. How random!
grumpfuttock1
ram: 4 GB
Quixote wrote:Taking a clue from grumpfruttock1, I switched my default browser to FireFox, opened PSP X3 and opened the help and it worked, bringing up help in FireFox. Then I switched the default back to IE 8, closed PSP X3 and reopened it and that worked, too. Now it seems to work in IE 8 consistently. How random!
Glad you had success too, Quixote :D
I also found that it worked perfect in IE8 after reverting back to IE8 as default browser (which I did after posting here), very strange though. I am wondering if under installation it somehow fails to register the default browser in some cases, thus when one tries to access help, it doesn't know where to look, hence the error message.
I guess you're smiling too !
raymondtatnell
operating_system: Linux
Post by raymondtatnell »
I had the same problem with IE9.I installed Google Chrome and it worked fine.I then un instaled Google and tried it again with IE9 and it works fine now.
