Can not render custom H.264 ?
EllieW
motherboard: Belarc says No details available
processor: 2.67 gigahertz Intel Core i5 750
ram: 4GB
Video Card: HIS Radeon HD 4670
Hard_Drive_Capacity: 1320.12GB
Post by EllieW »
Hello....
I am new to VideoStudio Pro X3 - I have created some simple videos using my webcam - brought them into VSP and edited and saved.
These are short clips 4 - 8 minutes long
When I try to create video file - custom - mpg4 - 640x480 - Compression H.264 Main (also tried H.264 BASELINE) VSP crashes
""This program has encountered an unspecified error and has stopped functioning.
Please contact Corel Technical Support and send the dump file for analysis""
I can render in any other format?? I am hosting at Amazon S3 and have been told the best codecs to use is the H.264 & AAC
Any advice is appreciated....
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Re: Can not render custom H.264 ?
Post by mitchell65 »
Hi EllieW and welcome.
We do need a lot more detail on this to be able to help you. Please look at this thread at the top of this Forum and give as much detail as possible especially the source file properties and exactly what you want to do with your finished file!
See this thread: http://forum.corel.com/EN/viewtopic.php?f=1&t=8959
John Mitchell
EllieW
ram: 4GB
Post by EllieW »
I am very new to doing this - not really understanding the whole process - I hope I have given you the info you need.....
Created several short videos with a Logitech webcam -- wmv file
Brought those into VSP version 13.6.2.21
The only editing that I did was to cut some pieces of the clips and to add a graphic with Title and a transition...
Saved as a VSP file
I am hosting these on Amazon Web Services (Amazon S3) - I was told to render them as a H.264 , AAC audio
Project Properties:
NTSC drop frame (29.97 fps)
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 16:9
LPCM Audio, 48000 Hz, Stereo
I open vsp project go to Share - Create Video File - Custom -
Save As Type: MPEG-4
Options -
Corel Video Studio Tab - I leave the boxes checked (Entire Project / Play file / Perform SmartRender / Perform nonsquare
General Tab - The only thing I change in here is the frame size to 640x480
Compression Tab - Video settings - I pick H.264 MAIN - also tried BASELINE
Tell it to save - it start to create a file and then I get the error message
And the program shuts down....
I tried other vsp files as I have 3 I am working on - each did the same thing - I unistalled VSP and then installed again... same problem
Finally I thought to try to create as a different file - sure enough I can create these as FLV or MP4 -- It seems to me I just can't use the
H.264 ??
Hope this is the info you need...
Post by Black Lab »
Try unchecking the SmartRender function and see what happens.
EllieW
ram: 4GB
Post by EllieW »
Black Lab wrote:Try unchecking the SmartRender function and see what happens.
I just tried this suggestion -- made no difference - it starts to create file and then I get the error and
the program closes.... :cry:
Post by Trevor Andrew »
You say your original files are WMV
Right click a clip in the timeline and select properties, what are they?
Your not gonna get better than the original quality.
Rob717
motherboard: Intel DP45SG Intel P45 Express Chipset
processor: Intel Core 2 Quad Q 9550
ram: 8 GB
Video Card: ATI Radeon 4870 1GB
sound_card: On-board
Hard_Drive_Capacity: 2 TB
Post by Rob717 »
Check what version of QuickTime you have installed, if you have version 7.6.6 then you will need to remove Apple Application Support, Apple Software Update and also QuickTime 7.6.6.
Once you have 7.6.6 removed then you will need to download and install QuickTime 7.6 (Here is the Link: http://support.apple.com/kb/DL762)
EllieW
ram: 4GB
Post by EllieW »
Rob717 wrote:Check what version of QuickTime you have installed, if you have version 7.6.6 then you will need to remove Apple Application Support, Apple Software Update and also QuickTime 7.6.6.
THIS WORKED!! I did have 7.6.6 -- I uninstalled (did not yet install 7.6) instead I went straight to VSP and was able to create using H.264!
Big Thanks!! :D
