X3 File Open crashes with Win7 64-bit
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
I have migrated to a new PC with Windows7 64-bit.
I installed my copy of PSPP X3 and it works fine except for two issues.
The File Open dialog always crashes the program when I use it
although Drag&Drop and Recent Files work fine.
Another (related) issue is that I cannot use Customize Scripts either.
Does anyone have any suggestions, apart from reinstalling?
Tadjio
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
Tadjio
sound_card: Sound
Re: X3 File Open crashes with Win7 64-bit
Post by Tadjio »
I have also discovered that if I invoke the Open File dialog
and then close or 'Cancel' then X3 crashes !!!
Tadjio
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Post by Trev Bowden »
Hi Tadjio Have we upset you in the NG.
I don't have a Real answer . Maybe its trying to open a previous folder that no longer exists. Not sure if resetting to default might work. Shift key on open.
Trev
Tadjio
sound_card: Sound
Post by Tadjio »
Hi Trev
Life's too busy to mess around in the NG :-(
Both with installing my super new PC (Win7, 64bit, i7x4, 8Gb, 2.5Tb etc.)
and with Real Life in the form of building work around our house and garden :-)
I'm still playing around with re-installing X3, following Simone's suggestions
including UAC, Cleanup and Run as Admin.
Possibly it's X3 Patch 2 (or 1) that is fouling it up.
Watch this space...
Tadjio
Tadjio
sound_card: Sound
Post by Tadjio »
I have finally managed to find the cause of this crash.
It occured once I tried to use the old "My PSP Files" from my previous Vista PC Installation.
Finally I found that if I place ANY Script in Scripts-Trusted or in Scripts-Restricted
then X3 crashes in any of the following circumstances:
1) Use File Open dialog - even if you Cancel out
2) Choose a Script in the Script Palette.
3) Use Customize Scripts
Can anyone else reproduce this?
(using Windows 7 Home Premium 64-bit ideally)
Tadjio
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Any script? Or any script from your old PSP Files folder? And any script any script? Or certain scripts? I mean did you actually test each script or just put them in and take them out?
Essentially I can put scripts in my scripts-restricted and scripts-trusted folders without any problems. Have for a while now. I do a lot of my own scripting. So I can't reproduce your problems with the information you gave.
Tadjio
sound_card: Sound
Post by Tadjio »
Yes, ANY Script :o
(but not other file types).
What Wndows OS are you using?
Tadjio
ram: 6 GB
My OS is listed to the side just like yours. :D Mine is the same but 32-bit not 64-bit.
Tadjio
sound_card: Sound
Post by Tadjio »
I never looked to the side for your OS :(
I was curious why the web board insists on all those details now
(but did not do so before when I registered)
all I wanted to update was my camera model...
Anyway, perhaps it is a 64-bit issue???
Tadjio
Trev Bowden
ram: 4gb
I am using 32 bit Win 7 So it might be a 64 bit transalation problem.
Have you tried adding 2 new script folder and putsome scripts into there then adding the location in File Locations. Now are these Custmize scripts to replace the Regestry entries? Maybe Win & and Vista disagre about wher the entries shold be.
Tadjio
sound_card: Sound
Post by Tadjio »
Thanks Trev, great idea. 8)
I created a new folder Scripts-Trusted-VISTA and
pointed to it in File Locations as a 3rd folder for Scripts-Trusted.
(The Corel default Program File folder also works and you cannot remove it).
I still can't put any Script into Scripts-Trusted itself.
I wonder if it is because I have pointed "My Documents" to Drive D:? :?:
Keep up the good ideas...
Tadjio
Allan Shearer
Post by Allan Shearer »
FWIW ... I'm getting the very same results (well, sort of) as you describe. Cannot do a 'File Open' (or Save), but I can Drag-n-Drop a file and it will open. Plus, I can double-click on a file and it will open. Just cannot go ANYWHERE NEAR the File Open / Save commands.
But here's the difference ... I'm not talkin' PSP, but Corel Script Editor.
My scenario:
- Clean install of Win7 Pro 32-bit.
- Installed Corel Ventura 8, which includes the Script Editor
- Installed Corel Ventura 10 (which doesn't . . . don't ask why)
- have all service patches up-to-date
Corel Ventura 8 and 10 work fine.
Corel Script Editor RUNS. But ... I cannot touch the File Open / Save commands. NOR can I use the script command GETFILEBOX - it too causes a crash, but, this might be unrelated. I only mention it because of it's relation to the File System.
I'd be VERY keen to know if anyone comes up with a solution for this.
At least this helps COMPLICATE the matter ... it ISN'T specific to PSP. Nor is it specific to 64-bit. Etc.
Allan Shearer
Ireland
