MF7e won't let me go to step 3 output
Several users have been unsure where to post issues relating to the copy of MovieFactory 7 SE now supplied with VideoStudio X3. To make life easier you can post problems here.
andrew43
motherboard: Belarc Advisor
processor: Belarc Advisor
ram: 4 GB
Video Card: Belarc Advisor
sound_card: Belarc Advisor
Hard_Drive_Capacity: 1 TB
Post by andrew43 »
Everything seems to work just fine in creating a menu (steps 1 and 2) then when I click on step 3 (outout) nothing happens. Any suggestions??
Re: MF7e won't let me go to step 3 output
Post by Black Lab »
If you called a mechanic and said my vehicle starts fine, but then it just shuts off, what do you think he would say? We need to know much more info - what kind of car you're driving, er, what kind of clips, etc. Please read the following and supply the requested info.
http://forum.corel.com/EN/viewtopic.php?f=1&t=8959
andrew43
ram: 4 GB
Post by andrew43 »
Ok, sorry about that, this is my first time actually posting in the forum. I've been using VS since version 5. Always been able to figure out problems before. I downloaded MF7e from the do more window. I rendered a VSP in Pro X3 to mpeg2 format. I brought that mpeg2 video into my MF7e and began creating my intro and menu. Step 1 and 2 went fine, I could preview it, looked good, went click on step 3 to render and nothing happened. I can go back check all settings, all seems fine, go back to step 3, same thing. I'm using a PC with Windowsw 7, 1 TB of storage, 6 GB of RAM and 64 bit. I hope this helps, if not let me know what else you need.
Thanks,
Andrew
madkitty
Post by madkitty »
same problem here - worked fine with my previous version that came with VS10 but for the life of me I cant access step 3...nothing has changed on my system from moving versions
madkitty wrote:same problem here - worked fine with my previous version that came with VS10 but for the life of me I cant access step 3...nothing has changed on my system from moving versions
First please go to your User Control Panel and fill in the information about your system. This might give us a clue, why you're having this problem.
You say nothing has changed... have you downloaded any other programs, purchased or trial? Do you still use the same DVD burner or have you upgraded to a Blue-Ray? When is the last time you upgraded DirectX?
