How to COPY AVCHD disks?
motor1
Post by motor1 »
It sounds silly, after spending one year editing a big project, to come down being unable to multiply my result. :D
I had rendered 4 AVCHD re-writable discs using Videostudio X2, it was painful but in the end, it came out pretty good.
I have tried to make more copies for some friends, but all came out not playable in Cyberlink Power DVD. The original re-writable disks are playing good in PowerDVD and Blue-Ray players.
To multiply the discs, I was using NERO, and some help from this totorial:
"Open Nero Burning ROM (not Nero Express, fine Nero Burning ROM in the Nero folder of your Start Menu. Look inside the Data subfolder and open Nero Burning ROM) and you will immediately see the New Compilation window.
If you do not see this window, then click File --> New or hit CTRL + N. You will now see your burning options (make sure DVD is selected, not CD). Scroll down the list on the left until you find the option for "DVD-ROM (UDF)". Select it as shown in the picture (click to enlarge).
You must now set the file system to UDF 2.50 or else the AVCHD disc won't be standard and probably won't work. Click the UDF tab as shown in the picture (click to enlarge). Under options, change to "Manual Settings (advanced users only)". Change UDF partition type to Physical Partition and change the File-system version setting to UDF 2.50. Once you have done that, click the big New button at the end of the program.
You now must add your AVCHD folders to your compilation once the program has loaded correctly (sometimes can take up to a minute). On the left is the compilation (what you want on the disc) and on the right is a file browser. Use the file browser on the right to locate the BDMV and CERTIFICATE folders.
When you find them, you can either add them to the compilation list on the left by right-clicking and selecting that option, or you can simple click the folders and drag them across the program, then release them into the AVCHD compilation. Make sure the BDMV and CERTIFICATE folders are at the root of the disc (they aren't inside any other folder on the disc). Once you have them added, you are ready to burn.
Click the Recorder menu and click Burn Compilation, or hit CTRL + B.
A new window will now pop-up that will give you a last chance to change any compilation settings you want, including the write speed. Whenever you are ready now, click the large Burn button to begin the process... and you will immediately get a warning (in Nero 7).
You will now get a warning informing you that the UDF 2.50 file system may in fact cause you some compatibility problems. This may be true of a regular DVD-ROM compilation, but what we are creating here is AVCHD and it must be UDF 2.50. Click the OK button to begin the burning process (for real this time).
The amount of time the burning process will take depends entirely on the amount of data being burned and the speed of the burning process.
If the burning process was a success (which is should have been) you will now be prompted with a message telling you so. Now run along and try it out. "
The only issue I remember is the controversy about the CERTIFICATE folder that some people say it should be there, some others say it shouldn't. The thing is that I don't have it (I guess Videostudio doesn't create it)
Any help from anyone who has more experience in copying AVCHD disks?
Forgot to mention the idea of copying disk-to-disk that should have copied over whatever was there didn't work.
Thanks everybody for sharing your knowledge, I have learned a lot so far!
Paul
DVDDoug
Moderator
Re: How to COPY AVCHD disks?
Post by DVDDoug »
I've never made an AVCHD disc, but I don't know why your copies wouldn't be identical to the original. Maybe you have some flaky blank discs or you're getting a "bad burn" for some reason.
It's also possible that there is a problem with the original... Player software can sometimes skip-over errors that the operating system won't ignore when you copy. But I don't think this is the problem, since you'd normally get an error message when you copy.
- Compare the files and file sizes on the original & copy with Windows Explorer to see if the copy & original "look" the same.
- Try copying the files from the "bad copy" DVD to your hard drive to see if it's readable.
- Try making an "image" file of the original disc (.IMG or .ISO), and then burn from the image. This should give you an exact copy with the same volume name, the files/folders in the same physical sequence etc. (I assume Nero can do that.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
I made several (over 50) copies during the 2 years that I create Hybrid DVD's. I just open "Nero Smart Start" and select "Copy DVD". That's all, no ISO,...needed.
motor1
Post by motor1 »
Thank you guys, I will try your advise (creating an image or again with CopyDVD).
I know it sound stupid, but this is what it is.
I have failed 6 disks so far, they all copy "well", no errors, but they won't play on the same machine I play the originals.
The information is there, but is still missing something...
erdna
processor: I7 4770
ram: 16GB DDR3
Post by erdna »
Also try another brand/type. For instance some JVC DVD players and Taio Yuden brand recordable discs don't like each other.
