Direct Link to Patch 2
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
http://www.corel.com/akdlm/6763/downloa ... Patch2.exe is the direct link to the second PSPP X3 patch.
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
ronzie
- motherboard: ASUS P4-800E Deluxe
- processor: Intel P4 3.3 GHz
- ram: 2 GB
- Video Card: PNY GT6800 AGPx8
- sound_card: Hercules Digifire 7.1
- Hard_Drive_Capacity: 360 GB
- Monitor/Display Make & Model: NEC Multisync P221W with Spectraview Calibrator
Re: Direct Link to Patch 2
Which brings it up to build no.?
Tim Morrison
- Moderator
- ram: 2GB
wildhoney
- motherboard: GIGABYTE GA-870A-UD3
- processor: AMD Phenom II X4 965 Black Edition
- ram: 12 GB
- Video Card: nVidia GeForce 9800 GT
- sound_card: on-board
- Hard_Drive_Capacity: 320 GB
- Monitor/Display Make & Model: LG Flatron F900B
Great thanks, Tim! I've already installed the update at work (where I have no Internet connection).
CorelDRAW Graphics Suite X5, Corel PaintShop Pro X5, Corel AfterShot Pro, Abobe Lightroom 4.3, Adobe Photoshop Elements 8.0, Windows 8 Pro x64
Here is a list of changes we made in the X3.2 patch:
- • Application stability improved
• Overall performance enhancements:- – Launch time improved
– Enhanced decoding performance for RAW files
– Faster filters
- – Canon EOS 550D / Digital Rebel T2i / Kiss Digital X4
– Canon EOS-1D Mark IV
– Canon PowerShot S90
– Casio EX-Z750
– Casio EX-Z1050
– Fuji FinePix S200EXR
– Fuji FinePix HS10/HS11
– Kodak Z981
– Olympus E-P2
– Panasonic DMC-G2
– Panasonic DMC-GF1
– Pentax K-x
– Samsung WB550
– Sony DSLR-A450
– Sony DSLR-A500
– Sony DSLR-A550
– Sony NEX-3
– Sony NEX-5
- – Repositioned rating controls in the Organizer
– New zoom-level indicator and zoom control for previewing in the Organizer
– HDR available in the Organizer
– Tabbed Document set as the new default in the Full Editor
Craig Copley
Tim Morrison
- Moderator
- ram: 2GB
I've noticed this in the release notes, but I can't find any way to initiate HDR from the Organizer. Anyone found how this is supposed to happen?cwcopley wrote:
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Are you talking about the HDR Photo Merge? Because that's just in the File menu. Click on it, and use it like you normally do. Or am I missing something as usual?
The File -> HDR Photo Merge... menu item was only enabled in the Full Edit mode prior to X3.2. We've now enabled it the Organizer. The integration is the same (opens another dialog) it's now just easier to get to.
Craig Copley
- ram: 6 GB
Not to sound ungrateful for making things easier, especially since I don't use HDR or the Organizer, but it looks like you simply added a menu item to a function that already existed.
If you were going to add it to the organizer wouldn't it have been good to also include the option to right-click on multiple selected photos and add them to the HDR Photo Merge from within the organizer? Would cut down on the number of steps necessary. But seeing as it's not a big deal, I believe most will take what they can get.
Tim Morrison
- Moderator
- ram: 2GB
Thanks Craig. I expected something like LeviFiction mentioned... highlight a series of photos in the Organizer and then use an icon or context menu item to send them to HDR Photo Merge.cwcopley wrote:The File -> HDR Photo Merge... menu item was only enabled in the Full Edit mode prior to X3.2. We've now enabled it the Organizer. The integration is the same (opens another dialog) it's now just easier to get to.
Glad to see HDR Photo Merge is usuable now that PSP isn't fiddling with very dark raw images. Be great if the Variable Number of Gradients demosaicing algorithm was retired (like it was long ago in all other raw converters), and the Raw Lab used raw data instead of a 16 bit/channel bitmap for its corrections.
Hope you can release a third patch soon. If the bugs that cause the tabs of tabbed palettes to be duplicated when returning from the Express Lab or Print Layout, and the bug that breaks scripts that utilise Tkinter were both fixed, I could use PSPP X3.
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
marty2010
- motherboard: Gigabyte Z68A-D3H-B3
- processor: Intel Core i7 2600k
- Video Card: NVIDIA GeForce GTX 550 Ti 1GB 8.17.12.8026
- sound_card: Realtek
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Viewsonic , VX2250WM-LED, 2 each
The Text Tool problem was fixed with patch #2.
Why was it not listed in the above post ... "Here is a list of changes we made in the X3.2 patch:"
Best Regards,
Vaughan Martell
Vaughan Martell
- ram: 6 GB
It probably fits under application stability. Even with the specifics given the list didn't exactly go into what application stability included. And it didn't mention fixes, only "improvements." You'll notice it doesn't mention any bugs at all, it only mentions what they improved upon or added.
marty2010
Levi,
Ok,
Then maybe this forum could use a "stickie post" of known Problem Fixes and Improvements per Patch Update.
And another list of Problems Reported.
And another list of Problems currently being worked on by Corel.
Just a plain English list of what is currently known.
Ok,
Best Regards,
Vaughan Martell
Vaughan Martell
Might be doable, by someone that may be keeping track of all these bugs. It could easily take up numerous pages per sticky.marty2010 wrote:Levi,
Ok,
marty2010
Ron,
What I meant was just a few words/one sentence to "log" the problem and a "link to the first post.
Then current: Solution/Workaround/Status.
#1
Edits are not saved after using Preview mode.
OriginalLink: here:XXXXX
Solution: Do not use the "ESC" Key to exit Preview mode. Use a mouse "click" on the Preview screen instead.
Corel Tech notified
#1
Corel Tech notified
Best Regards,
Vaughan Martell
Vaughan Martell
