I've done a few checks but I can only find one bug that has been fixed. That was was the bug that automatically over-brightened dark raw files (see http://forum.corel.com/EN/viewtopic.php ... 15#p195146 or news://cnews.corel.com/4b80cf01_1@cnews). This bug made it impossible to do anything with very dark raw files, occurred everywhere in X3 and as a consequence made the HDR Photo Merge tool unusable.
The bugs I've tried that haven't been fixed -
- Going from the full editor to either the Express Lab or Print Layout, then returning to the full editor, causes the tabs of any rolled up palettes to be duplicated.
- Any script that uses Tkinter will crash. (Tkinter is used to draw dialog boxes in scripts).
- Some icons, such as the black Free Rotate icon or the Text Tool's "Remember Text" icon are extremely hard to see.
- Some vector text will not print. It shows up OK on screen, but won't print.
- The normal way for all images to open in all previous versions PSP has always been in a window. If that option isn't changed, all images open in a window, no matter how they are opened. In PSPP X3 the image is shown in a window if PSP is already open, but maximised if PSP is not open. For instance, if X3 is closed and you open an image using Open With, The image will open maximised. If you run X3 first, then open an image using Open With, that image opens in the Windowed view. Another example is if you send an image to X3 from another application such as an external image viewer like FastStone Image Viewer. It will open in a windowed view if X3 is already opened, and in maximised view if X3 is closed.
