I wrote a script that uses some 8 bit tools. If the image is 16 bits the script freezes. If I try adding a Decrease to 8 Bits command and the image is already 8 bits it freezes the script.
How would I go about having the script automatically determine the bits and decreasing (or increasing) as needed? I'm not opposed to learning Python but have no experience with it as of yet.
Thanks in advance.
Scripting help
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Scripting help
Regards, Dan
Trev Bowden
- motherboard: ASUSTeK. M3A78-EM
- processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
- ram: 4gb
- Video Card: ATI Radeon HD 5450
- sound_card: ATI HDMI Audio.Realtek High Definition
- Hard_Drive_Capacity: 2TB
Re: Scripting help
You might Be better writing to the PSP scripting News group where I expect Suz Shook will be only too willing to help
[url]news://cnews.corel.com/corel.PaintShopPro_Scripting[/url]
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Scripting help
That is an excellent idea as they will have a whole lot better idea than the rest of us. However my NewsReader claimed it couldn't connect to the news group. Sad day. Maybe you'll have better luck, df, but if you don't here is what I know of the subject.
And some Python is necessary as you'll be doing conditional statements. First you need to get the Image Info from PSP
You can use any variable name you want. This returns a dictionary that you can look through to get what it is you want.
Then you look at either the BitDepth or PixelFormat. Of course PixelFormat has multiple 8-bit image formats so BitDepth would be what I'd look at. But the scripting group will better be able to answer that question. However, since 16-bit format has a BitDepth of 48 you compare it like this.
Python relies very heavily on indentation spaces to determine what code belongs to which parts of the script. For example the code to do conversion needs to be indented properly under the "if statement" to let Python know that it belongs to that if statement. And you can't mix indent styles. You can't use Tab on one line and 4 spaces on the next. They have to be the same indentation type.
Since that wasn't very clear or helpful go talk to the people who know what they're doing.
Code: Select all
Variable = App.Do(Environment, 'ReturnImageInfo', {'GeneralSettings' : {'Version' : ((9,0,0),1) }} )
Code: Select all
if Variable['BitDepth'] == 48:
#Not 8 bit image, perform conversion
#the rest of your commands here.
df
- ram: 64gb
Re: Scripting help
Trev
I've never used a newsgroup before and don't know how to sign up or post or anything else that I don't know how to do. I tried it but got a Windows Mail error.
Levi:
I tried adding your text to a copy of my script, then copying the decrease color depth text as well but I still keep getting error after error. Most were indentation errors that I was able to stumble through (thanks for the heads up on that one) and after a bit of noodling around with it I think I have it working properly.
Here's the code that I have so far
and the script goes on from there but you get the idea.
Dan
PS is there a way to edit further in script editor rather than Notepad? I'd like to change one variable in a different part of the script and can't open the script to edit it like it used too.
I'm pretty certain that my newsgroup program is Outlook 2003 if that's any help."This message could not be sent.
No sender was specified. Please check your News Account configuration."
Levi:
Code: Select all
from PSPApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Photo Pro',
'Host Version': u'13.00 Alpha 00000000.0000000000.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((13,0,0),1)
# Decreasecolordepth
'Version' : ((13,0,0),1)
App.Do( Environment, 'DecreaseColorsTo16Million', {
Dan
Regards, Dan
- ram: 6 GB
Re: Scripting help
No, once it's edited with python code PSP no longer knows when where what and why things are the way they are. But the value you want to change should be properly labeled in the corresponding command and you can edit it that way. Or is it a slider of some form?
As for newsgroups I found a PDF that helps you figure out how to set it up for a very specific news group but the instructions are almost identical for Corel's newsgroups.
http://www.fhcrc.org/about/pubs/center_ ... ks2003.pdf
When it tells you to enter "news.fhcrc.org" replace that with Cnews.Corel.com.
When you're given the newsgroups you can subscribe to select the Paint Shop Pro Scripting one from that list and subscribe to it. You can then send and recieve updates from there.
It's a little different for Thunderbird but I finally got it working so with these instructions, which look really easy, you should be fine.
df
- ram: 64gb
Re: Scripting help
Yeah, it's a slider. Knowing I can't edit it the way I'm used too is good to know. So my work around was using the original script I was working off of (I used a copy to screw with, always a good habit) adjusted what I wanted, saved, then copied and pasted the appropriate text into the proper spot. Worked like a charm.No, once it's edited with python code PSP no longer knows when where what and why things are the way they are. But the value you want to change should be properly labeled in the corresponding command and you can edit it that way. Or is it a slider of some form?
I've yet to join the newsgroup but I probably will. Thanks
Regards, Dan
Trev Bowden
- ram: 4gb
Re: Scripting help
You might want to try Context for script editing. It understands Python indents and uses colour codes to differentiate between variables cod and comments
http://www.contexteditor.org
oh Did i mention that its free
