I did some Ulead effects in a video clip & then converted it into a Mpeg (in Ulead) to put it back into Windows L. M. Maker since that was where my original project was & it couldn't be read unless converted.
Then once my profect was completed I took the Windows L. M. Maker .wmv file and put it back into Ulead to convert it as a Mpeg file since needing it to be in the Mpeg format.
#1)My question is can the above be done without loosing quality?
#2) I have to format the video for Public Access which uses Leightronix/Total Impact software and they are not able to capture the video onto their computer but only play it off a certain dvd player...what needs to be done in regards to formatting so there is no problem on their end in capturing it?
#3) Also, I need to burn dvds that will be universally compatible..do you know of any dvd software that is?
(I've tried Roxio & Windows Dvd Maker and neither is working.)
#4) The Ulead dvd burning option isn't in my software program?? Any ideas on where it would be?
Thank you
