Interviewing with 2 DV cameras?
daddog
Post by daddog »
Thought I would ask as it kinda ties in with my around the corner purchase of X3.
I have done many of our school year books on DVD's using Video Studio. I was thinking about doing some 'interviews' using two cameras. Have never looked into it before and thought I would ask here. I gather I can just hook the cameras up to a laptop and each would record directly onto a HD. That correct? Would or could I then edit it using X3 or would I use some other software?
Thanks in advance. :)
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
joosuna
System_Drive: F
processor: intel dual core 3 Ghz
ram: 12Gb
Video Card: nvidia
Hard_Drive_Capacity: 2000
Re: Interviewing with 2 DV cameras?
Post by joosuna »
The process of using two video cameras requires downloading the video of each camera, separately. You will end up with two files. Lets call one A and the other B. The editing program has several available video tracks. In this case you will use two video tracks. A video on the first video track, and B video file on the second video track. Now you need to synchronize the two tracks ( assuming you had both cameras "on" at the same time ). After you synchronize the two video tracks, you can cut and delete from one of the video tracks. If you wish to keep the sound constant, you need to drop on of the synchronized original video files onto the audio track. That is the way I do it, but, I am sure there are many other variations from the members of this forum. You then save the edited version as a final video file, through the "Share" or save project process.
daddog
Post by daddog »
Thanks sir! And this can all be done in X3?
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
joosuna
System_Drive: F
ram: 12Gb
Video Card: nvidia
Post by joosuna »
yes, it can be done with x3
Post by Trevor Andrew »
There are some tutorials on You Tube, I found Multi-track Video Editing - VideoStudio Pro X3
Should give you some ideas.
http://www.youtube.com/watch?v=tHI7fw0wZfw
download Video Studio X3 trial version and give it a run.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
recording direct to hard drive requires specialised software, so as noted above record to tape and capture to pc and edit.
For the entire length of the interview keep both cams recording, or you'll end up with lots of syncing problems.
Right before you start use a clapperboard or just clap your hands in front of the camera, this will give you a moment in time to sync the two tracks.
Post by Black Lab »
The Tutorials section of this forum also has some threads on Multi Cam editing.
Post by BrianCee »
Having synchronized the two video tracks it is VERY IMPORTANT that you do not cut and remove sections of the top track - that will cause the remaining video to slide left to close the gap and lose your synchronisation. I would mute the second track sound completely and only rely on the sound from the top track. Now when you want the footage from camera A to display simply remove the covering bit of video from the B track. if you dot not remove video from track B then that will show on your final video - so you should end up with a continuous video in track A but with sections in track B
daddog
Post by daddog »
Gentlemen, you are a huge help. :) Thank you so much!
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
