This is the first time I am handling HD footage and thought it would be piece of cake but it transpires to be a piece of marble.
Any help would be much appreciated.
trevor andrew wrote:Hi
David how did you get the footage from the camera to your pc.
The image shows a serious case of wrong Field Order, at least that’s how I view it.
Your camera seems to record to memory card, (SDHC ) as such you should copy the data from the cameras memory card to your pc/hard drive,
then insert the video to the timeline.......Is that how you did it?
trevor andrew wrote:Hi David
Are you saying that you rendered/recoded your video files??????????????
You should transfer/copy the video from the SDHC card to your pc, probably via USB.
Then insert the video to the timeline.
Right click the timeline and select Insert Video, browse for your video files.
Compression can be a confusing word, think of it as a video format, initially there is no need to re-code the video files. Providing your pc is up to the job, please refer to Kens earlier comments…….
Then it depends on what you intend to make, if you are making a standard DVD then your video files/project will require rendering to allow the burning of a DVD.
So can you tell us how you got the video onto the pc and any changes/recoding/rendering you may have performed, and what you intend to make.?
