Though I would not expect it to run very fast, does anyone have any opinions on how VS Pro X3 would run on my present computer? It is a Pentium 4 3.0 processor with HyperThreading running XP Home with current Service Packs and 1.5GB memory, plenty of hard drive space. I am currently running VS 11.5+ and it is slow but not unbearable. Any siginificant rendering jobs I leave for overnight processing.
Another question: would the libraries I have created in my present VS be usable in Pro X3 (assuming I save them appropriately before installing X3)?
I would like to upgrade if only to be able to read/edit h.264/mpeg4 video without converting it first.
Thanks for any advice/comments.
Video Studio Pro X3 requirements
babyleon
- motherboard: PEGATRON CORPORATION 2A86 1.04E01
- processor: Intel Core i7 930 2.8GHz
- ram: 12.0GB
- Video Card: ATI Radeon HD 5450
- Hard_Drive_Capacity: 7+ TB
Re: Video Studio Pro X3 requirements
If you are talking about AVCHD/h.264 mpeg-4, then you had better forget it. Your computer is just not up to the task. Believe me, I know, as I have an identical one (now moved to the role of second back-up computer). You might manage to edit it using SmartProxy, but a P4, even 3.0 GHz with HT, simply can't play AVCHD... Just before upgrading my computer, I tried editing some AVCHD and managed it, but it played back very jerkily -- in effect unwatchable. I thought at the time that the editing was similarly bad, but when I played the edited video on a (then new) Core 2 Duo, it played back fine. So that is what you would need at the very least for AVCHD: a decent Core 2 Duo, or Quad, or better still one of the new i-core 5 or 7...
babyleon
- ram: 12.0GB
Thanks Ken. I was afraid of that.... I don't know if I want, make that "can afford to", take the leap to a new computer just so I can add some mpeg4 video directly to projects without converting it first. I am still only rendering to regular DVD format for my finished DVDs even though I am filming all in HD (using Canon HV30s and a GoPro Hero HD - the one that produces the mpeg4 format stuff that I would like to add directly). I can use Super C (free) to convert my mpeg4 to mpeg2 for use in my current projects on my current computer.
A related question: If I take the leap to a Core i-7 computer with gobs of ram and such, and if I buy the VS Pro X3 upgrade, will I have to first install my present VS 11.5+ on the new computer in order to install the upgrade?
Also, any ideas on being able to use my VS 11.5+ libraries in VS Pro X3?
Thanks so much.
Thanks so much.
Accolades
- motherboard: Gigabyte GA-EX58-UD4
- processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
- ram: 12 GB DDR3
- Video Card: Nvidia GeForce GTX 295
- sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
- Hard_Drive_Capacity: 4TB +
X3 Seems to run OK on my system
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
My Vimeo Channel:
babyleon
- ram: 12.0GB
I went ahead and purchased VS Pro X3 (boxed upgrade) direct from Corel. I still have the same computer and would like to at least give it a try for editing my existing DV files. If I make a backup executable copy of my present VS 11.5+ program files on my second internal hard drive, would I likely be able to install X3 there without affecting my present installed VS11.5+ version and libraries on my C: drive? That way, if it doesn't run fast enough, I might be able to just go back to my VS 11.5+ until I can afford a faster/newer computer. Any guesses?
Yes, you can have multiple versions of VS on the same computer.
Jeff
Dentler's Dog Training, LLC
