Slide show
CarworldHQ
operating_system: Vista Ultimate
System_Drive: F
motherboard: Asus px5
processor: intel
ram: 2gb
Video Card: nvidia
sound_card: realtek
Hard_Drive_Capacity: 400gb
Slide show
Post by CarworldHQ »
Hi and thank you for reading. I am making a slide show using ulead video editor. The pictures once inserted have a duration time of 3 seconds. I wish to increase the duration to 8 seconds. Is there a way of changing the duration on all images (batch) or can you only do this individually. I have a lot of pics so a batch change would save a lot of time.
Thanks Tony
Re: Slide show
Welcome to the forums,
Depending on what version you're using, is where the command is found. In the current version VS Pro X3 look under the Edit menu for Change Photo/Color Duration. For all versions prior look under the Clip menu for Change image/color duration.
Just select all your photos the normal windows way, by clicking on the first photo, then holding down the [Shift] key, go to the last photo and click on it. Then go to the Edit or Clip menu to select the command. A dialog window will open where you can set the new duration.
CarworldHQ
System_Drive: F
processor: intel
ram: 2gb
Video Card: nvidia
sound_card: realtek
Re: Slide show
Excelent. Thank you for your reply, this has saved me a lot of time.
tkm
motherboard: GIGABYTE
processor: Core 2 Dual E6750
ram: 4GB
Video Card: NVidia GF240
sound_card: On Board
Hard_Drive_Capacity: 3TB
Re: Slide show
Post by tkm »
Further, Is there any method to change the default photo duration from 3 second to 8 seconds?
As I also want to use a default 2 second transition duration. Using the default 3 second duration will cause a insufficient media length error and trim it back to 1 second. It will be great if I can set the photo duration to 8 seconds.
Re: Slide show
Post by Trevor Andrew »
Hi tkm
View the Preferences folder I think under Edit Tab can change image and effects durations.
X2 and earlier File – Preferences
X3 Settings - Preferences
