Tool Text Tool crashes the program ..Help
Gehilda
- motherboard: Asus P5KPL- CM
- processor: Intel Core 2 Duo
- ram: 2GB
- Video Card: NVidia
- sound_card: on bord
- Hard_Drive_Capacity: 320GB
Hello everyone I'm new here, and thank you for accepting me.
I installed Paint Shop Pro X3 and funcina fine, but suddenly now when I write and use the Text Tool ferrementa the program crashes. I desesperaao, Can anyone help me? how do I fix this problem?
Since already thank you.
Gehilda
Gehilda
marty2010
- motherboard: Gigabyte Z68A-D3H-B3
- processor: Intel Core i7 2600k
- Video Card: NVIDIA GeForce GTX 550 Ti 1GB 8.17.12.8026
- sound_card: Realtek
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Viewsonic , VX2250WM-LED, 2 each
Re: Tool Text Tool crashes the program ..Help
Gehilda,
Have you "searched" for information on this forum?
http://phpbb.ulead.com.tw/EN/viewtopic.php?f=56&t=38251
Best Regards,
Vaughan Martell
Vaughan Martell
Gehilda
- ram: 2GB
Hello thank you for responding, before I post and even before I tried login to the Forum. But there is another problem, mine is only text and found no information to help me, so I asked for help
This is the windows error I was getting:
Name faulting application: Corel Paint Shop Pro Photo.exe, version: 13.0.0.0, time stamp: 0x4b3b2b3d
Name of module failures: ToolText.dll, version: 13.0.0.0, time stamp: 0x4b3b2998
Exception Code: 0xc0000005
Displacement failed: 0x0002b87f
Process ID failed: 0x1ba8
Start time of the faulting application: 0x01cb10df55195b06
Faulting application path: C: \ Program Files \ Corel \ Corel Paint Shop Photo Pro \ X3 \ PSPClassic \ Corel Paint Shop Pro Photo.exe
FCaminho module failures: C: \ program files \ Corel \ Corel Paint Shop Photo Pro \ X3 \ PSPClassic \ Commands \ ToolText.dll
Identification Report: b3abeb50-7cd2-11df-948f-001fc6c2cddc
As I understand it and error appears in Windows the problem is different.
But you who understand the program and think it's the same problem I apologize and will not be repeated again.
Thank you for your attention and response.
A big hug
A big hug
Trev Bowden
- motherboard: ASUSTeK. M3A78-EM
- processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
- ram: 4gb
- Video Card: ATI Radeon HD 5450
- sound_card: ATI HDMI Audio.Realtek High Definition
I too Had This problem after doing some test on the text tool on behalf of another user I did the trick of holding down the shift key as i clicked the X3 icon to reset the application to Default. Some other user found it was because the fill or stroke (or both ) was set to null when clicking the text tool so When it happened again I tried that But it did not work. So I used reset again.
If you have customised the workspace and not saved it Your going to have to do it all again . You could save the workspace now but be aware that could save whatever causes the problem Too.
Gehilda
- ram: 2GB
Trev
Thank you for the tip, and then I'll try to report what happened.
A big hug
Gehilda
A big hug
Gehilda
Gehilda
- ram: 2GB
Problem solved: Re: Tool Text Tool crashes the program ..Hel
Problem solved.
I did this procedure below and it worked:
1. Inside Paint Shop Pro, go to File | Preferences | Reset preferences.
2. Check delete all Cache files.
3. Click Ok.
4. Try the tool that was giving you the problem and note if behavior continues.
Thank for help and Marty and Trev.
3. Click Ok.
None of this is working for me. When I click on the text tool in pspX3 it completely freezes the program. I can't even close it....I have to shutdown my computer to get it off my screen. Any other suggestions??
marty2010
Do you have Corel updates 1 and 2 installed?
Best Regards,
Vaughan Martell
Vaughan Martell
I don't think I've ever received an update. I just tried the "reset preferences" again and it just isn't working. I have to close down my computer to get the pspX3 off my screen. Where do I get these upadates? Thank you
marty2010
Click on "Help" then select "Check for Updates".
Best Regards,
Vaughan Martell
Vaughan Martell
Okay, I clicked on "Help" and it did have an update to download so I clicked okayh. It goes through the process of updating then stops and says paint shop pro must be closed to continue. When I close down paint shop pro the download screen goes away too!!!
How else can I download the update?? thanks again, I really appreciate the help.
Nancy
Nancy
marty2010
Start PSP again and see if you get it back.
Best Regards,
Vaughan Martell
Vaughan Martell
Okay, tried again to no avail. Everything works fine but the text tool. This time I was able to close psp without shutting down my computer. I tried to google for the update but can't find it anywhere.
Nancy
Nancy
Nancy0FF][/color]
