to save a clip?
jhanajian
- motherboard: FOXCOMM ALOE 1.0
- processor: 2.80 gigahertz AMD PhenomIIx4 925
- ram: 6136 MB
- Video Card: ATI Radeon HD 5450
- sound_card: Realtek HD
- Hard_Drive_Capacity: 570GB
to save a clip?
I used the Multi Trim Video feature today for the first time. All worked fine until I tried to save a clip -- File/Save Trimmed Video. Then I got a message which says: "The frame size (416 x 240) of the video file does not match the settings and therefore cannot be trimmed." What do I do to save a clip? Thanks for you help.
Re: to save a clip?
Is that the actual size of the clip? Where did you get it from?
Jeff
Dentler's Dog Training, LLC
jhanajian
- ram: 6136 MB
Re: to save a clip?
Yes, that is the actual size of the clip, as stated in the clip's property details. I got the video at the Internet Archive http://www.archive.org/details/nature-1. The video is an MP4 file.
jhanajian
- ram: 6136 MB
Re: to save a clip?
Okay, it looks like I've found the solution to the problem. The Project Properties settings (under Settings) is set at 720x480. The video being clipped has to fit that same frame size exactly or the program will not let you save the clip. I ran the video through a video file converter a couple of times, changing only the frame size each time. I could save the clip only when the frame size matched the Project Properties settings. This is rather unfortunate because those settings are not very flexible, and if I want a larger size clip (dimensionally),I'll have to run the video through a video file converter a couple of times -- once before and once after -- in order to get the bigger clip.
