Burning to DVD+R
gordon_fan_24
Burning to DVD+R
Post by gordon_fan_24 »
My project was edited in VS7, and rendered to a MEPG-2 I used the next steps to create a DVD+RW and a DVD+R. The DVD+RW worked great, but the DVD+R would not burn. I go into MF3 and import the clip. Then I go through the menu setup. I get to the burning DVD screen, after telling it to create a DVD image file I try to burn the disc. On the DVD+R I get an error message telling me that there is no disc in drive when I know there is. Is MF3 compatible with +R's?
Texas_bret
Post by Texas_bret »
I don't have MF3 but I do have a SE version of it that I have used to burn +R disc (the main type disc I use) with no problem using a Sony burner. My guess would be that it is compatible based on my experience. Good luck.
T_Scheen
Post by T_Scheen »
I can reassure everybody: Since I have MF 3.0, I have burned only to DVD +R discs and never ever encountered any hick-ups during burning or on any stand-alone DVD-Player when played.
Try creating an iso-file or Video_TS-files instead with MF 3.0 and burn them with Nero. If you encounter the same problems there, I assume something is wrong with your DVD-Drive or its driver-software.
videomartin
Post by videomartin »
Are the Burning patches installed already and the fix for 16x Burners ?
T_Scheen
Post by T_Scheen »
No, I don't think so. I am burning to DVD only (Speed=4X).
A complete patch-description can be found here:
http://www.ulead.co.uk/tech/dmf/dmf_ftp.htm
Thomas
