Using Pro X2.
I have downloaded a video file into the edit section of Pro. X2. I now require to select a potion of the music and use it later in another clip.
Is there any simple way I can do this?
Saving Sound from video- info. required.
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Re: Saving Sound from video- info. required.
In VS 10 once the video clip is in the timeline, you select SHARE then select CREATE SOUND FILE. I'm sure that X2 would be similar.
John a
If you only want a small section Alan then look immediately under the preview screen at the progress bar - at each end you will see a small triangle - using your mouse drag those triangles in from each end to select only the bit you want. A red bar will appear in the timeline showing the selected portion, now when you follow the above instructions and go to 'Share' >> 'Create Sound file' make sure you select the option to produce a sound file from the selected portion only - not the full project. This will save a .wav file in the working folder defined for your project.
Alan - please fill in more of your profile so that it appears at the right like mine - it will help us to help you in any future questions you may have - Thank you
Thanks, Brain and jparnold, for your replies.
