videostudio 7&8 capture problem
vscarc
Post by vscarc »
every time i attempt to capture a video from my panasonic dv camera it would record for a few minutes then stop capturing. this happened with vs7 and vs8 also with dvd moviefactory. i d-loaded new updates, updates directx, got new firewire cable and cardbut still having the problem. i have a p4 266 with 512 memory 60gb harddrive avermedia 1394pci capture card. can u help me. i remember when i had vs6 i had no problem
heinz-oz
Post by heinz-oz »
How much free disk space do you have? When did you defrag your drive last?
vscarc
Post by vscarc »
52 gb free space did not defrag my hard drive yet. will try now
THoff
Post by THoff »
If you are capturing directly to MPEG2 format instead of DV AVI, then your system is likely unable to keep up with the realtime transcoding process, and when the internal buffer fills up, it stops to clear the backlog of data. This is normal.
GeorgeK
Problem?
Post by GeorgeK »
What is a P4 266 ?
THoff spoke about MPEG2, can you give more detail about what your trying to do? Are you transfering DV Video from DV Tape via Fireware to your hard drive (to a separate partition or to the same partition as your OS and programs?), as DV type 1 or DV type 2 AVI file (this will take about 12 GB for 1 hour of DV footage) ?
If you give people a little more detail, they will have more to go on and maybe give a better answer.
THoff
Post by THoff »
I think the 266 is the speed of his RAM/FSB, not the CPU -- 266MHz RAM is also known as PC2100...
