Burning onto DVD +R DL
wesley_4024
motherboard: ECS Nettle2 1.0
processor: AMD Athlon 64X2 Dual Processor 6000+ 3GHz
ram: 3.0 GB
Video Card: NVIDIA GeForce 6150SE nForce 430 [Display adapter]
Hard_Drive_Capacity: 500.11gb
Post by wesley_4024 »
I am using Corel Video Studio Pro X2 and i have a project that has a duration of approximately 175 minutes. I purchased a Verbatim 2.4x DVD +R DL DVD which has a storage capacity of 240 minutes, which should hold my project. However, when I went to create the DVD, Corel said that my project exceeded the capacity of my DL DVD.
Can anyone tell me if there is a simple solution to this problem. Prior to purchasing the DL DVD, most sites stated that almost all DVD recorders and players were compatible with this new technology so I don't think it would be my DVD burner. I'm all ears at this point though. I really don't want to have to start removing stuff from my project to make it fit.
Re: Burning onto DVD +R DL
Post by Black Lab »
Is your burner rated to burn DL's?
Post by Trevor Andrew »
Hi wesley_4024
Welcome to the forum
Assuming the answer to Jeff question is yes………
From the burner module, final window--lower left select your DVD type as DVD 8.5 Gb
Easily overlooked……….
If that is not the solution , give us some details of your project and the convert settings under the cogwheel.
Are you adding a video or a project to the burner module?
Oh by the way, just burned my first DL, had to update the firmware before i got a result, two coasters.
