I installed the free trial of 2010 Pro, when I tried to launch the program I got this error:
Faulting application windvd.exe, version 10.0.5.298, faulting module unknown, version 0.0.0.0, fault address 0x001ec628.
I uninstalled, reinstalled but got the same error
XP Home SP3
Can't run WinDVD 2010 Pro
Moderator: lata
nepenthe
- motherboard: Gigabyte GA-P55A-UD3P
- processor: i-7 860
- ram: 16 GB
- Video Card: Gigabyte GeForce GTX 470 SOC
- sound_card: onboard Realtec audio
- Hard_Drive_Capacity: 600 GB
- Monitor/Display Make & Model: NEC MultiSync EA192M
Re: Can't run WinDVD 2010 Pro
jjis -
Please see 2 May'10 reply by nepenthe:
http://bit.ly/9WgBZH
Also see 9 June'10 reply by nepenthe:
http://bit.ly/dAcSBt
nepenthe
nepenthe
According to the support site, the patches are not for the trial version
Rob717
- motherboard: Intel DP45SG Intel P45 Express Chipset
- processor: Intel Core 2 Quad Q 9550
- ram: 8 GB
- Video Card: ATI Radeon 4870 1GB
- sound_card: On-board
- Hard_Drive_Capacity: 2 TB
The patches are included in the download for the trial, there is no need to try and install the trial.jjis wrote:According to the support site, the patches are not for the trial version
Update Direct X:
Use the Microsoft Direct X End-User Runtime installer to make sure that Direct X is up to date
http://www.microsoft.com/downloads/en/d ... layLang=en
Make sure that the Windows Compatibility mode is disabled:
Right Click on the WinDVD Pro 2010 icon | Select properties | Select the Compatibility tab | Make sure there is nothing enabled on the screen, if there is disable it and apply the changes and try WinDVD pro again
Try performing a clean boot of Windows XP:
Select Start | Run | Type: msconfig | Select OK | Select the Startup tab | Select Disable all | Select the Services tab | enable hide all Microsoft Services | Select Disable all | Scroll through the list and re-enable Protexis Licensing V2 | Select Apply | Close msconfig | Reboot and then try launching WinDVD
If all of the above fails, manually remove WinDVD Pro 2010 and then create a new admin account and then try re-installing the program
1. Log on to a user account with administrative privileges since "Limited" or "Power User" accounts won't let Corel software install, uninstall, or run properly.
2. Disable your anti-virus/spyware, and firewall during this clean re-installation procedure.
3. Delete the following folders/directories:
* For Windows 32-bit: C:\Program Files\Corel\CorelWinDVD2010
* For Windows 64-bit: C:\Program Files (x86)\Corel\CorelWinDVD2010
4. Go to Start >> Run and then type: regedit
5. Hit the enter key to launch the Regedit utility.
6. In the Regedit window, make sure that the following entries are removed:
* My Computer\HKEY_CURRENT_USER\Software\Corel\DVD10
* My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Corel\DVD10
* My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SOFTWARE\Corel\DVD10
* My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SOFTWARE\Corel\PCU\
* My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Software\Microsoft\Windows\CurrentVersion\Uninstall\5C1F18D2-F6B7-4242-B803-B5A78648185B
* My Computer\HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\5C1F18D2-F6B7-4242-B803-B5A78648185B
7. Close the Regedit.
8. Clean up temporary files and Recycle Bin by launching the Disk Cleanup from Start menu >> Programs >> Accessories >> System Tools >> Disk Cleanup.
9. Restart your computer.
