x3 crashes when rendering mp4 hd
cshudson
motherboard: Sony Vaio F11
processor: intel I7
ram: 4gb
Video Card: NVidia 310M
sound_card: Realtec
Hard_Drive_Capacity: 500GB
Post by cshudson »
drag a 2 minute 1440x1080 60i clip in th etime line
drag a flash object infron of the clip
add text on the flash object
select transitions and add disolve between flash animation and video file
select share tab, and select Create Video File
select Mpeg-4, then mpeg-4 HD
X3 render window pops up and app crashes everytime.
Anyone else?
Re: x3 crashes when rendering mp4 hd
Why are you selecting mpeg-4 then mpeg-4 HD? Why not go directly for AVCHD (which is of course high def mpeg4)?
cshudson
processor: intel I7
ram: 4gb
sound_card: Realtec
Post by cshudson »
A Better question would be why does it crash when using an option that Corel gives us. If Corel gives us 50 options to do the same thing, none of the 50 should cause the app to crash.
That said, I will try using the AVCHD menu and see if it fares any better latter in the day.
It all depends what you are after, which in this case I suspected was AVCHD. I suspect -- though confess I am not 100% sure -- that the mp4 option in VS uses one codec which comes as part of Windows, while the AVCHD option uses a separate H.264 HD codec installed by VS...
cshudson
processor: intel I7
ram: 4gb
sound_card: Realtec
Post by cshudson »
Using the AVCHD template crashes as well, it crashes at 15% instaed of 2%. I have contacted Corel about this as well.
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
From which camera brand (codec version) does your footage come from? Did you uncheck smart render?
cshudson
processor: intel I7
ram: 4gb
sound_card: Realtec
Post by cshudson »
Canon HG10 which uses AVCHD
Never checked/unchecked smart render. I'll give that a shot and report back.
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
I have the same model camcorder, also my system is very close to yours cshudson. I always use the AVCHD choice in the "Share" "Create a video file". I then choose 1440 x 1080.
I have just done test with those settings with a video clip from my camcorder (M2TS file) Put a flash clip of the spinning world in the front of the clip, inserted the crossfade transition and put a title to run across the flash clip. Put two random transitions in the video clip faded the end to black and put an end Title in. The went to share as above. Rendered complete no problems.
One question I would ask; How do you transfer your clips from the camcorder to the PC? What file extension do the files on your PC have? May sound an irrelevant question but there is a reason for asking!
John Mitchell
cshudson
processor: intel I7
ram: 4gb
sound_card: Realtec
Post by cshudson »
The only difference I see is that I was choosing the 1920X1080 to render so x3 would have to resample, or whatever it is it does to fill the pixels. the files were imported using VSx3 I believe and are AVCHD fils with the ".MTS" extention. Do you have smart render enabled or disabled?
cshudson
processor: intel I7
ram: 4gb
sound_card: Realtec
Post by cshudson »
I think you found it. When I choose to export in the same resolution as the original, 1440 x 1080, it exports fine. When I ask it to upsample to 1920x1080 in either the AVCHD or Mpeg-4 menus, it crashes. Can you confirm this on your system?
Any idea why that would be?
