Hi there. I bought the whole package in February so I'm still learning, but... in the separate software called PSP Project Creator using collages etc it says you can choose different styles from the drop down menu. Well all I can get on my drop down menu is "Fun" style. In collages I get lots of different layouts to use in the "Fun" style but "Fun"style is all I get. In the Photobook it is the same.
Should there be MORE styles than just the "Fun" style?
I have looked and looked for an answer but to no avail.
Can someone help please?
Thanks,
Phil.
PSP Project Creator styles
Phil47
- motherboard: ASUS Z170-P DDR 4
- processor: i-5 6600K OC
- Video Card: GTX960
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: Asus MX279
- Corel programs: PSP X6 PSP X9 PSP 2018
Tell the truth....but gently.
Phil.
Phil.
Trev Bowden
- motherboard: ASUSTeK. M3A78-EM
- processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
- ram: 4gb
- Video Card: ATI Radeon HD 5450
- sound_card: ATI HDMI Audio.Realtek High Definition
- Hard_Drive_Capacity: 2TB
Re: PSP Project Creator styles
As for collage no just the one but Land scape of Portrait but once you have added the images you will find that there is also a chose of Layouts, Lots of em.
Phil47
Thanks but why,when in "Collages", does the help page say "choose different styles from the drop down menu"?
phil
phil
Phil.
Phil.
Trev Bowden
- ram: 4gb
The help files say
2 In the Project name box in the Create Collage window, type a name for your project.
3 Choose a style by clicking one of the thumbnails at the bottom of the workspace.
4 Click Select photos.
Well there are two thumbnails
Phil47
Trev,
Yes, you are correct but it also says at the bottom, "You can also
Change the style for the collage
Click the Styles tab in the Media Tray, choose the option you want from the drop-down menu, and click a style thumbnail."
However, it doesn't seem to say at what point you can do this. My point is that there is no point in having a drop down menu if there is nothing on it.
Am I missing the point here?
Phil.
Phil.
Phil.
Phil.
Phil47
Also, when I have added 4 photos to the collage and auto filled the layout and then go back to add more more photos to the media tray
and then go back to the collage it has not added the new photos to the collage. I can add them manually ok but is that the only way it works?
Thanks,
Phil
Thanks,
Phil
Phil.
Phil.
marty2010
- motherboard: Gigabyte Z68A-D3H-B3
- processor: Intel Core i7 2600k
- Video Card: NVIDIA GeForce GTX 550 Ti 1GB 8.17.12.8026
- Monitor/Display Make & Model: Viewsonic , VX2250WM-LED, 2 each
Phil,
Each time you add a photo .. click autofill again.
Also, did you select the options in the hidden menu at the right side of your screen?
Best Regards,
Vaughan Martell
Vaughan Martell
