VSP failure to open
wkadams
VSP failure to open
I am doing a large video project which involves many VSP files. After sometime of not working on them, I went back to the project. I find now that some of project (VSP) files will not open. When I select one of them to open, nothing happens. I get no message or anything. Others opening normally. Any thoughts?
WK Adams
Re: VSP failure to open
What version of VS are you using now, and have you used other versions in the past.?
mitchell65
- ram: 4Gb
If the VSP files that you are having trouble with were produced using a version prior to VS x3 and they are stored on an external hard drive I found I needed to temporarily load them to my C drive open them OK in VS x3 save them again to the original place on the Ext drive overwriting the original and then they will in future open normally in VS X3 and then you can delete them from the C drive.wkadams wrote:I am doing a large video project which involves many VSP files. After sometime of not working on them, I went back to the project. I find now that some of project (VSP) files will not open. When I select one of them to open, nothing happens. I get no message or anything. Others opening normally. Any thoughts?
John Mitchell
