MPEG-4 AVC (x264) Codec in VideoStudio Pro X3?
jonathan75
motherboard: Dell Inspiron 531
processor: AMD Athlon 64 X2 Dual Core 4400+
ram: 4GB
Video Card: NVIDIA GForce 8600 GTS
sound_card: Onboard
Hard_Drive_Capacity: 1TB
Post by jonathan75 »
Hello,
I do a lot of video recording from my Canon Camera. It saves the video in this format:
Video: MJPG 640x480 30.00fps 15097Kbps [Video 0]
Audio: PCM 11024Hz mono 88Kbps [Audio 1]
And I always used Avidemux 2.5 to convert it to MPEG-4 AVC (x264). I like this codec and it makes it nice and small/good quality to upload to Facebook for my family to see the baby. But in VideoStudio Pro X3 I don't see this codec there. Is it under something else or how do I install it for this program? I tried the MP4 codec for YouTube but I don't like the quality. It has too many artifacts.
Thanks,
Jonathan
jonathan75
ram: 4GB
sound_card: Onboard
Re: MPEG-4 AVC (x264) Codec in VideoStudio Pro X3?
I tried downloading this codec but the problem is during motion from the special effects. It looks interlaced with lines in it. Is there a way I can fix that? I didn't have that problem with the MP4 YouTube codec but then it looked blocky overall.
http://www.free-codecs.com/download/DTS_x264_VfW.htm
jonathan75
ram: 4GB
sound_card: Onboard
Bump, any Codec pros?
Post by Black Lab »
Does you camera record in Lower Field First or Upper Field First? You must be outputting the same, or you may get the problem which you describe.
joepic
motherboard: MSI X58 Pro-E
processor: i7-920
ram: 12 GB
Video Card: GTS-250 1 GB RAM
sound_card: built in
Hard_Drive_Capacity: 1.4 TB
Post by joepic »
[quote="jonathan75"]Hello,
Jonathan,
Check our my post to see how to use h.264 codec in VS X3 for different formats: http://forum.corel.com/EN/viewtopic.php?f=1&t=38106
jonathan75
ram: 4GB
sound_card: Onboard
Thanks for the tip Black Lab, that got me in the right direction. I changed it to Frame-Based and it worked great!
joepic, I tried that configuration but it did not work good. The video looked very poor. I like to use an AVI container and the X.264 codec. Under the settings you used it let you select .264 but I couldn't select which codec. I would like to create a custom filter but it will not work right. I can only get it to work if I set it myself every time. It is very strange. The settings are the same but it will not work if I save it as a profile. The video file would end up being 4 times as big and not play right. So I just hit custom every time and enter the settings.
Post by Black Lab »
8)
TangentVector
System_Drive: D
ram: 3 GB
Video Card: NVIDIA
sound_card: M-AUDIO
Post by TangentVector »
jonathan75 wrote:Thanks for the tip Black Lab, that got me in the right direction. I changed it to Frame-Based and it worked great!
I'm doing the same thing with my Sony Alpha DSLR and it's not working. Unfortunately when I was uploading the tainted files to my computer a lot of my personal information was compromised. I lost a number of Microsoft Office files including Outlook e-mails, Excel spreadsheets, and a few publications I was working on in Word and Publisher. I never imagined that digital files from an external camera would force me to run disaster recovery software, but it had to be done, and I am becoming a bit frustrated with some of the bugs in Video Studio.
What is your Sony's recording format? The OP in this topic, has a MJPEG, that uses Frame Based. Post the Properties of your video clip. You can right-click on a clip in the Library or timeline, select Properties. Are you also using VS X3?
