frame based
dpriest
frame based
Post by dpriest »
Using VSX3 I noticed that when I go to render a video to mpg, frame-based is the default setting, instead of lower field first. When would someone want to use frame-based in a project?
Accolades
motherboard: Gigabyte GA-EX58-UD4
processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
ram: 12 GB DDR3
Video Card: Nvidia GeForce GTX 295
sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
Hard_Drive_Capacity: 4TB +
Re: frame based
Post by Accolades »
Fill in your details in User Control Panel.
Provide more information on where the source video is coming from and properties.
Frame based is used when creating slideshow of photos - normallly
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
Re: frame based
How do you manage to choose Share > Create Video File > MPG in X3? I ask because one complaint about X3 is that that choice has been dropped. All that is available in the mpeg stakes is 'DVD' (i.e. DVD-compatible .mpg). And in my version of X3 at least, the default field order for that is Lower Field First. (I have never changed that anywhere as I no longer make SD DVDs...)
But apart from that observation, as Accolades says, Frame Based is mainly used for slideshows of still images. There is also a possibility of using a frame based video as a precursor to a high definition progressive file (eg 720p) which bears some similarities to frame based...
Re: frame based
Post by Trevor Andrew »
Most if not all video used for the internet are Frame Based
Video for You Tube should be frame based
Ipod video, Mpeg4 types will be frame based.
WMV is frame based.
Interlaced,
Upper or lower field order is generally used for Standard DVD intended for TV playback.
High Definition can be Frame Based (720p) or Interlaced (1080i)
