Hi. So I've been working on this problem for hours. I have created my movie in VideoStudio12 and then I try to share the video on Youtube and convert into a .flv file or create a video file, to any format. I have gotten two errors. One would act like it was converting the file and then at a certain percentage say "unable to load library 19151:3:3." The other problem that is happening more now, is it acts like it's converting and then just stops. When I try to click on something, it has the hour glass forever. I look in the Task Manager and the program is not responding.
I have installed the patches on the website and removing the smart rendering. I just can't seem to get anywhere on the program to convert and upload to Youtube. Thank you!
Video Studio 12 freezes when converting from .vsp to any oth
Re: Video Studio 12 freezes when converting from .vsp to any
Hi sumsmiles
Welcome to the forum
There have been problems with Unable to Load Library in the past.
Please do a search for other related posts.
I don’t know if a positive solution was ever found, others on the forum may be able to help.
In the meantime….
The 3D transition effects seem to be the culprits, but I cannot confirm this.
At the point where the video fails to render, (your certain percentage) whats in the timeline?
If you are using transitions then try replacing with another type.
Direct X
Have you manually updated Direct X, updating has cured some problems with Video Studio, there is a post at the top of this forum.
In the meantime….
Direct X
sumsmiles
- motherboard: Aspire 5534
- processor: AMD Anthon x2 dual core processor l310 1.2ghz
- ram: 4gb
- Video Card: not available
- sound_card: not available
- Hard_Drive_Capacity: 285 gb
Thank you. That was it. I had to download DirectX from Microsoft and it works now.
