Problem creating disc
I am new to VS Pro X3, but not new at all to the VS family. Everything about x3 has been great up to the point of rendering an mpeg clip. I then open x3 and select new project, share, create disc, which now opens dvd factory which is a complete disaster. It seems to hog all my resources opening, then creates a library of my music and picture folders, which I don't want it to do. All I want to do is to navigate to the folder where my video clip is that I created, load it, set up the menu and burn it to a disc like I was aqble to do in all previous versions of VS. What is the secret in disabling all the fancy, resource hogging extras in dvd factory and just create a disc the old fashioned way which worked, and worked quite well???????
Re: Problem creating disc
I don’t have VS 3 so am limited in the help I can give.
There is a sticky post at the top of this forum New authoring module for X3
May be worth a read………….
Also if you have older VS versions then you could use those to burn your completed Mpegs
