Can't capture HD video
garybowers
- motherboard: asus P6T
- processor: Intel i7-920 2.66Ghz
- ram: 12GB
- Video Card: EVEA Ge Force GTS 250
- sound_card: soundblaster Audigy SE 7.1
- Hard_Drive_Capacity: 1.75TB
When I try to capture HD Video from my Canon HF10 Pro X3 doesn't recongnize the camorder or will lock-up untill I disconnect the USB cable and the the program will start working again, but will still not capture or load any video. What am I doing wrong?
mitchell65
- ram: 4Gb
Re: Can't capture HD video
Hi gary and welcome to the Forum
I think your camcorder records to a card? That being so did you not have software provided with the camcorder to transfer the files direct from the card to the PC. It is always best to use the manufacturers supllied software to transfer your files. I think you will find that your camera records to MTS format wheresas when the files are transferred through the supplied software they take on the M2TS extension. VSx3 prefers this format, it often has problems with MTS files.
John Mitchell
kd5om
- motherboard: Lenovo
- processor: Quad Core
- ram: 8gigs
- Video Card: Gforce GTS250
- sound_card: On board sound card
- Hard_Drive_Capacity: 1TB
Hey Gary,
I have the same issue. I got spoiled having VSPX3 link directly to my old Sony tape camera and pull the videos right into the VSPX3 via a Firewire connection. I've spent the past hour researching this same issue. I recently purchased the HF20 camera. The only way to transfer videos I have found is to launch the Canon Transfer Software, then connect the camera USB and power connector. Then you need to press the transfer button on the camera itself. On my HF20 (yours maybe similar) it's the lower right button on the viewing screen.
If come up with another method please let me know and I'll do the same. I don't like being totally dependant on having to have the computer my software is loaded on to transfer videos off my camera.
Jerry
Jerry
Jerry K.
http://www.kd5om.com
mitchell65
- ram: 4Gb
Hi Jerrykd5om wrote:Hey Gary,
Jerry
If you use two PC from time totime there's nothing to stop youputting the Canon software on both. You will only use one at a time fter all. It relly is better to use the software provided by the camcorder manufaturer as the resultant files cause less problems in editing IMHO
John Mitchell
tgwiz
- motherboard: Gigabyte GA-EP43-DS3
- processor: Intel Pentium 4CPU 3.00GHz 2CPUs 3.0GHz
- ram: 1024MB
- Video Card: NVIDIA GeoForce 8600 GT
- sound_card: HDAUDIO FUNC_01 VEN_10EC DEV_0662 SUBS
- Hard_Drive_Capacity: 580GB
I have completely failed to capture video from a Canon MV901 DV Camcorder which uses mini DV tapes. I can capture with WinDV via firewire but never with VS Pro X2. So I went out and bought X3 and it also results in "Corel VS Pro... is not working" and closes it down. Having paid out for two versions and not even being able to get started makes me very frustrated. Please help.
Mav
- motherboard: PEGATRON CORPORATION Eureka3 1.01
- processor: 2.67 gigahertz Intel Core2 Quad Q9400
- Video Card: NVIDIA GeForce GT 230
- sound_card: AVerMedia H789 PCI-E Hybrid DVB-T
If you purchased the product through the Corel online store then they provide a 30 day money back guarantee. I have just exercised my right to this refund as for me VideoStudio Pro X3 just does not do what it is advertised to do. In my case I am unable to use this product as it is sold to create a DVD as the application continually terminates immediately the Create DVD button is selected.tgwiz wrote:I have completely failed to capture video from a Canon MV901 DV Camcorder which uses mini DV tapes. I can capture with WinDV via firewire but never with VS Pro X2. So I went out and bought X3 and it also results in "Corel VS Pro... is not working" and closes it down. Having paid out for two versions and not even being able to get started makes me very frustrated. Please help.
It makes no sense to continue buying Corel products if they are not working for you, save the aggrevation, time and effort and try a different product.
tgwiz
- ram: 1024MB
Yes, I'm coming to that conclusion too, especially as since my last posting I've tested it out on different computer using Windows XP and had exactly the same outcome. I just wish though there was some form of informed response from Corel here that admitted their deficiency and offered a solution. I guess that's too much to ask!
