can I alter image length en-masse?
- Screwball
- processor: Quad 3.2
- ram: 8gb
- sound_card: soundblaster platinum
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: HP2010i x2
- Corel programs: Pro X6
I have made quite a long DVD entirely of images and sound. After burning I realise that every image is a tad too fast for the music to compliment i.e. the music is soft and melodic yet the images (7secs) with a 2 sec transition either side appear to be irritatingly fast. To cut a long story short, I want to increase the images lengths by 1 sec, but, there are so many it would take me longer than our MP's deciding who's to govern Britain to achieve. Is there a way I can perhaps format the whole video with my required image length? Had I realised before viewing, I know I could have set the length in preferences - too late now!
Re: can I alter image length en-masse?
What are you using? In X3 you simply select the clips, right click, and choose Change Duration.
Jeff
Dentler's Dog Training, LLC
- Screwball
- ram: 8gb
Hi, thanks for response, are using VS11 have tried to select clips by selecting first to last while holding down shift but just selects last clip. If I can get this to work, I assume it will not alter transition length?
With VS 11, you need to:
1. Select the first clip
2. Press and hold down the Shift key
3. Select the last clip
4. Go to the Clip menu and select Change image/clip duration.
The duration of the transitions will not be affected..
