Please contact Corel Technical Support and send the dump
itxaspe
motherboard: Dell Inc. XPS M1330
processor: Pentium Dual Core T-4200
ram: 4GB
Video Card: Mobile Intel GMA X3100
sound_card: SigmaTel
Hard_Drive_Capacity: 80GB
Post by itxaspe »
Good morning.
Here I explain the error that we're facing (in spanish).
http://www.imh.es/sarea/aupa-tux-es/cor ... -dmp-file/
I'll try to explain it in english:
Working in a windows XP . Our original files are MTS files. And we want to export the project in :
Create Video File: MPEG-4:MPEG-4 HD template.
Some files could be transformed without problem, but others is impossible. We always get this error
The program has encountered an unspecified error and has stopped functioning.
Please contact Corel Technical Support and send the dump file for analysis
C:\Doc.. \Usuario\….\Temp\vstudio_1.6.0.272_20100308_015620.DMP
We have made a lot of tests. The hard disk is ok, the memory is ok. We've testint in other pc, with the same results. Sometimes it fails (a lot of times) , others OK..
Is there some problem in converting from MTS to MP4?
Ahh.. we've installed DirectX last updates. And also a corel video studio pro x3 patch (the program itself says there's an update and suggestes to install it).
In corel's database, there's no patch for Video Studio Pro X3: http://www.corel.com/servlet/Satellite/ ... 2796559943 ??
Thanks in advance. I'm wasting a lot of hours .. ;(
Accolades
motherboard: Gigabyte GA-EX58-UD4
processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
ram: 12 GB DDR3
Video Card: Nvidia GeForce GTX 295
sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
Hard_Drive_Capacity: 4TB +
Re: Please contact Corel Technical Support and send the dump
Post by Accolades »
I am sure this has been answered before?
MTS files are MPG4 (highly compressed) ?
If so you will better off converting them to MPG2 format prior to editing.
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
itxaspe
ram: 4GB
Post by itxaspe »
Thank you for your answer.. but..
That's not a good solution, as far as I think, no? Ufff.. we bought this product to be able to work directly with the MTS files..
Why some videos goes perfect, and anothers don't?
corel Video Studio X3:
Enhanced! Import from HDV™, AVCHD, Blu-ray Disc™ and JVC® HD camcorders (as they see in the product characteristics)
Then, it's supposed to be able to edit AVCHD format (MTS in my camcorder) without problem. That's why we upgraded from Ulead Video Studio 11 to Corel Video Studio X3.
We tested the product before we upgraded without problems and now.. it's failing sometimes.. There must be another answer, otherwise Corel Video Studio X3 is not valid to be used with AVCHD.. not?
Thank you..
Normally, an AVCHD camera will come with some software made by the manufacturer -- at least that happens with Sony and Panasonic camcorders. I am not sure about others. So normally I recommend you first import the video from your camcorder to your computer hard drive using that software. That usually converts the AVCHD native .mts to AVCHD m.2ts (which is still the same mpeg-4 and high quality, same as the original). But Video Studio seems to be happier dealing with .m2ts that native .mts.
itxaspe
ram: 4GB
Post by itxaspe »
Well... it's true that it comes with a software.
The strange thing is that some videos OK and others not?
I'll give this a try.. and we'll tell.. ;)
Thanks in advance and have a nice week-end
itxaspe
ram: 4GB
Post by itxaspe »
I'm facing a problem with this.
The camcorder came with HD Writer 1.0, and as we didn't use it, we have loose the CD.. ;(
Now I'm trying to get the same version (1.0) , but there's no way.
I've tested with HD Writer 2.5, but this version doesn't let me choose the Hard disk of the camcorder. It sees ok the SD disk, but not the Hard Disk.. ;(
Can you help me in some way?
Thanks in advance
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
itxaspe wrote:I'm facing a problem with this.
Thanks in advance
You don't say the make and model of your camorder but if you go on to the manufacturers website have a look for software specific to your camera.
John Mitchell
mitchell65
ram: 4Gb
Have just found where to download HD Writer 1.
Try this link:http://software.informer.com/getfree-hd ... -download/
John Mitchell
itxaspe
ram: 4GB
Post by itxaspe »
mitchell65 wrote: You don't say the make and model of your camorder but if you go on to the manufacturers website have a look for software specific to your camera.
Panasonic.. HDC-HS300 . In the website there're only updates, but not the program itself.. ;(
mitchell65 wrote: Have just found where to download HD Writer 1.
Trying this link, by the moment with now success.... i'll try again and again! ;) Thank you very much, i'll tell you if I can get it .. ;)
itxaspe
ram: 4GB
Post by itxaspe »
There's no way.. the link you told me is an update of the program, not the program itself.. ;(
http://panasonic.jp/support/global/cs/s ... ee_w7.html
another link or someone who have the program?
Thanks! ;)
Flevobird
System_Drive: D
motherboard: HP Intel H67 Express
processor: Intel i7 2600 3.4 GHz
Video Card: MSI GeForce GT630 - 4GB
sound_card: On board
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: LG 24"
Post by Flevobird »
itxaspe wrote:another link or someone who have the program?
I'm sorry; I've only got the new one. The reason I do post here is that I also have the same kind of problems with my .mts files and want to test like mister Ken Berry suggest and I like to give you a handout to use your newer version of the software. I own a Panasonic HDC-SD700 camera and bought Videostudio X3 because it can import Dolby 5.1sound from the camera. :D
I prefer newer versions of software. When you use HD Writer 2.5, you automatically get .m2ts files imported on your disk. You can copy your .mts files back to a SD-card (notice using the original directory structure!) and re-import them with HD Writer. After that you can use .m2ts files directly in Videostudio. If .m2ts files are better indeed to VSX3 HD Writer will be my standard import tool. Unfortunately I don't have time for testing the next few days. :cry:
I hope these files will work, then I also can start editing my video's ... success!
Richard
Camera: Panasonic HDC-SD700, 3MOS Full-HD with Dolby 5.1 sound
Video-setting: AVCHD 1920*1080i, PAL
Authoring software: Corel VideoStudio Pro X7 Ultimate
