DVD MofiveFactory 6 + large file
Martinigue
System_Drive: E
motherboard: Makalu
processor: Intel C2D
ram: 4GB
Video Card: NVidia
sound_card: Realtek
Hard_Drive_Capacity: 380
Post by Martinigue »
Hello all,
I have a couple of large avi's which I want to burn onto dvd disks for use in a standalone dvd player. By large I mean size which, when the corresponding avi is loaded into Movie Factory, exceedes the capacity of an ordinary dvd ( 4.7G). What options do I have?
1. Can I set up the project so that it would span multiple disks? If so - how? Was looking in th eproject options but to no avail ...
2. If I burn it as plain avi, how can I make sure the dvd player will recognize the codec? Did this a couple of times and everytime the player went 'disc unsupported', while all I kow about the player is that it can play avi files but more detailed info like what codecs are supported is unobtainable ( it is Philips Diga DMR-ES10). It does not support double layer discs, though...
Any help is appreciated!
Mac
DVDDoug
Moderator
Re: DVD MofiveFactory 6 + large file
Post by DVDDoug »
What's the total playing time?
Here is a handy online bitrate calculator to help you fit your video onto a DVD.
Since the DVD format (MPEG-2) is different than "AVI", it's more about playing time than the size of your AVI file. You can fit 90 minutes of very good quality video and Dolby audio onto a single-layer DVD. You can sqeeze more than that onto a DVD by using a lower bitrate, but if the bitrate goes too low, you start to notice quality loss.
Two different "projects"?
For playing on a DVD player, its best to tell Movie Factory to make a Video DVD. Movie Factory will then convert the video to MPEG-2 (VOB files) and format that video to the standard DVD format with a VIDEO_TS folder, etc.
NOTES - AVI is not a single format. It's a "wrapper" of "container" format and it can contain video in any format. Some formats are more compressed than others. AVI/DV is less compressed than DVD (MPEG-2) and AVI/DivX is more compressed than DVD. It's also possible to have an AVI file with MPEG-2 video.
If you know the bitrate (combined audio & video) you can estimate the file size in any format:
File Size in MB = (Bitrate in kbps x Playing Time in minutes) / 140
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
Martinigue
System_Drive: E
motherboard: Makalu
ram: 4GB
Video Card: NVidia
sound_card: Realtek
Thank you for the info, it definitely will be helpful during my next try.
One more point: I did play with the bitrate number already but the result was - the size of the output was ok, but during playback the audio came out slooooowed down; what was my mistake, then?
DVDDoug
Moderator
Post by DVDDoug »
...but during playback the audio came out slooooowed down; what was my mistake, then?
I don't know... That shouldn't happen... But, a lot of things "shouldn't happen". :twisted:
Have you confirmed that your file is DV/AVI? If you're in Movie Factory with your file(s) showing on the time-line, and you right-click on the file, I believe it will show you the "properties". You can usually make a DVD from DV without any strange things happening... With more-compressed formats, problems are more common...
If the audio has slowed-down but the video has not, your audio & video are completely out-of-sync, right?
Audio speed is more-related to sample-rate (kHz), than bit-rate (kbps). But, this is almost never a problem since the file header is supposed to tell the software the sample rate. For video, speed is related to frame-rate (FPS = frames per second).
As a work-around, you can try converting your AVI file to MPEG-2 with SUPER (FREE!!!) before bringing it into Movie Factory. To make sure it's DVD-compatible MPEG-2, choose the same settings (resolution, framerate, etc.) as Movie Factory is using, and choose AC3 audio. Then in Movie Factory, click the box that says "Do Not Convert Compliant MPEGs".
No time to think.
Out of... sync.[/i]
