Running X2 and Windows Movie Maker on Same Machine
michaeld121
Post by michaeld121 »
I’ve installed VideoStudio Pro X2 on my new Windows 7 Laptop. There are 1 or 2 things I use Windows Movie Maker for, so I’ve installed WMM v2.6 as well. However when I open WMM after about 2 seconds it tells me that: “Windows Movie Maker has stopped working. A problem has caused the program to stop working.”
I had a similar problem with WMM on my old Windows XP laptop, but found that as soon as I removed X2, WMM then worked fine. Does anyone know if there’s anything I can do get them both working on the same laptop at the same time?
Thanks,
Jedzi
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Re: Running X2 and Windows Movie Maker on Same Machine
Post by Clevo »
When WMM stops working can you check the Event Viewer in Windows 7 to find clues as to what caused the crash? Report back here. They shouldn't conflict like that but it seens they are sharing a resource they don't like sharing.
michaeld121
When the error message appears there's this error logged in the Event Viewer:
Faulting application name: MOVIEMK.exe, version: 2.6.4038.0, time stamp: 0x4b14069d
Faulting module name: KERNELBASE.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdbdf
Exception code: 0xc06d007e
Fault offset: 0x0000b727
Faulting process id: 0x770
Faulting application start time: 0x01caeada7415aa9c
Faulting application path: C:\Program Files (x86)\Movie Maker 2.6\MOVIEMK.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
When I click on the "Close Program" button on the error message there is an "Information" event logged:
Fault bucket 1756987013, type 1
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: MOVIEMK.exe
P2: 2.6.4038.0
P3: 4b14069d
P4: KERNELBASE.dll
P5: 6.1.7600.16385
P6: 4a5bdbdf
P7: c06d007e
P8: 0000b727
P9:
P10:
C:\Users\Michael\AppData\Local\Temp\WER10D5.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\Michael\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_MOVIEMK.exe_f6e465cc95cde18eab7bea6ea0a5446ca9792646_11846480
Analysis symbol:
Rechecking for solution: 0
Report Id: b35ba22b-56cd-11df-b483-705ab68601da
Report Status: 0
I have to admit that I don't know my way around the Event Viewer, so I hope this is what you were asking for. Pls shout if it was something else.
Thanks,
Jedzi
Clevo
ram: 4GB
Post by Clevo »
Yes thanks...that's all the information that is required.
I've done a Google search on the kernelbase.dll error that you are getting it seems to be a fairly common error with no known default fix.
You may want to try uninstall WMM and re installing again...this seems to be the most common fix on other software that use the kernelbase.dll file and that have issues when loading.
If that doesn't work then you may need to try and avoid having both open at the same time
Reason: Google Search Link Inserted.
michaeld121
Clevo wrote:...
Just before trying to delete WMM I uninstalled Corel DVD Copy ... and I can now open and use WMM, which is really good.
I've never really used Corel DVD Copy and AFAIK I can use the Toshiba or Microsoft software that came with my laptop.
Thanks for your help,
Jedzi
