I have tried installing both the try-before-you-buy download, and using the link to the download which is in my receipt for the purchase. I realize I probably should have tried the try-before-you-buy installation before I bought, but well...I didn't.
I run Windows Vista, completely up-to-date. I have tried the download with both Firefox, and IE, which are also both up-to-date. Pop-up blockers, ad blockers, etc are disabled. I am not using any download managers. I have no other applications running when I attempt the install, and have temporarily uninstalled all anti-virus and malware protection. I have tried the x3 installation with x2 installed, and x2 uninstalled. The Vista account I'm installing to is an administrator account, and I have also tried using the right-click "run as administrator" on the installation .exe
I suspect the problem has something to do with Corel's download manager. I Googled "iNOSSO", and it is associated with "getplus", which I also discovered is the download manager plug-in that Corel uses. I believe getplus also manages the compression and "zipping" of the installation file.
When I try to download the installation file with Firefox, I get the usual "Would you like to save this file?" dialogue, and the installation file .exe downloads normally. --But then gets the above stated error message when executed.
When I click the exact same link in IE, interestingly, I'm directed to a new page with a short set of instructions on how to start the download, and there is a little orange, animated Corel icon that says "Download Now!". When I click this, I get a standard "Do you want to run or save this file?" dialogue box. Per the instructions, I select "run", and then again "run" on the subsequent box. A file called IEGetPlugin.exe is downloaded, but then an error message appears that says "IEGetPlugin[1].exe has stopped working | Windows will close the program and notify you if a solution is available."
I Googled IEGetPlugin, and that is the getplus download manager plug-in that Corel uses. I have no idea why it won't run properly on my system.
Any help with this would be much appreciated.
Thanks,
Andrew
