Multiple Issues- slow startup, cut/paste quirks, and more
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Re: Multiple Issues- slow startup, cut/paste quirks, and mor
Post by Trev Bowden »
Copy and Paste will place as new layer it dead centre in the image. Promote to layer will keep it in the same position but on a new layer.
But neither will not alter that original layer. Not a big user of Float as I prefer to have my selection on a new layer so that i can reposition as many times as I like. But float will float the selection allowing it to be relocated until defloated but its does alter the original. More like Cut and paste as against copy and paste
Simone Corel UK
Alludo
Post by Simone Corel UK »
Thanks for explaining, Trev Bowden. I supposed a deeper secret behind that float. Okay, I always duplicate the layer and after move it to that place I want to have it.
Crichton
operating_system: Vista Home Basic
motherboard: laptop
processor: T9300
ram: 4GB
Video Card: nvidia 8600M GT
sound_card: realtek
Hard_Drive_Capacity: 400GB
Post by Crichton »
@ Simone : because when you're done with paste, is when the bug comes out: you don't end up with a perfect copy of what you've copied, because a bounch of pixels are missing. If I understand correctly, Trev Bowden was trying to find a workaround to this problem before the patch was coming out, that is duplicating an area without using copy/paste. In spite of this, I found the bug persisting even trying to circumvent it through duplicating layers.
case a)
select region
copy
paste
deselect region
-> some pixels disappear.
case b)
duplicate layer
flip/mirror/do somethin with the new layer
flatten the layers
-> some pixels disapper again
Trev Bowden
ram: 4gb
Ignore For some reason I could not see my post
Trev Bowden
ram: 4gb
Its the float that is causing the problem as I see it. Doing the selection and then doing cut followed by paste as new layer. Then selections none and move to position does not lose pixels in my tests
Simone Corel UK
Alludo
@ Crichton
I personally find it much more difficult to reproduce this floating thing (even with a 5000% zoom). I was lucky to reproduce it twice but 99% of all tests fail.
Simple duplicating the layer, moving to the right place or choosing the Mirror and merging both is no problem.
marty2010
motherboard: Gigabyte Z68A-D3H-B3
processor: Intel Core i7 2600k
Video Card: NVIDIA GeForce GTX 550 Ti 1GB 8.17.12.8026
sound_card: Realtek
Monitor/Display Make & Model: Viewsonic , VX2250WM-LED, 2 each
Post by marty2010 »
I have this problem also.
Created a circle (any size) and filled it with black (raster layer).
Just make a selection (raster layer).
Right arrow (move one pixel).
Floating layer automatically created.
Then, "select none".
Floating layer automatically deleted.
Now missing bottom row of pixels.
Happens every time.
Without any zoom.
Best Regards,
Vaughan Martell
Simone Corel UK
Alludo
Unfortunately, that is what I get most of the time
not me.JPG (66.55 KiB) Viewed 9074 times
Trev Bowden
ram: 4gb
Curiouser and curiouser. My first thought on this was a Graphic card problem especially as both of the first examples where NVida cards so I tried it and got the same results. Now I was just going to repeat the test with screen caps to show th resulting steps but I cant repeat it. Each time i tried i don lose any pixels I set up guides to prove to my self that no pixels had disappeared. :shock:
marty2010
sound_card: Realtek
Post by marty2010 »
"Each time i tried i don lose any pixels I set up guides to prove to my self that no pixels had disappeared."
My lost pixels, as in my last last screenshot, are always easy to see without the need for set up guides.
And it is not an intermittent problem. I always lose them.
Best Regards,
Vaughan Martell
Crichton
motherboard: laptop
processor: T9300
ram: 4GB
sound_card: realtek
Post by Crichton »
It's true, the bug not always presents, and I didn't manage to isolate the exact conditions under which it does yet.
I did some tests to capture it in a movie and it took three tries to obtain this video where the bug occurs:
defloat-bug.zip
copy, paste, select none: bug
(24.51 KiB) Downloaded 383 times
marty2010
sound_card: Realtek
Post by marty2010 »
Just wondering if you tried the test I posted?
Best Regards,
Vaughan Martell
Trev Bowden
ram: 4gb
Yes I did your steps Marty and Got this
What can I say. I did get the missing pixels some days back But now I don't
marty2010
sound_card: Realtek
Post by marty2010 »
Trev,
Right. OK. Thanks for verifying.
The only way I have it working (so far) is by using your workaround:
"If You have not yet discovered it Here is a work round. After making the selection instead of float. promote to a new layer then make original layer active and delete . Now use move or pick tool to move the top layer. No missing pixels. OK its a few steps more but you could script it and set it as a bound script called Float".
Best Regards,
Vaughan Martell
Trev Bowden
ram: 4gb
Its Rare that I use copy paste preferring to drag layers from the layer palette on to images But try also Select Cut then paste as new layer I don't think that will lose Pixels
